Paccar MX-13 Crankcase ventilation pressure sensor location
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TruckYou, May 9, 2024.
  1. TruckYou
    TruckYou Bobtail Member
    14
    Mar 3, 2016
    Hey Guys,
    I'm getting a code of P1402 crankcase ventilation pressure - voltage too low or short circuit to ground on PCI....
    I'm trying to locate the crankcase pressure sensor but am unable to, does anyone have a sensor diagram? I have a 2015 KW T60 Paccar MX-13.
    Thank in advance!
  3. JB7
    JB7 Heavy Load Member
    953
    1,647
    Dec 13, 2022
    Laurel, MD
    Paccar MX11 / MX13 I6 Engine Sensor Locations – TroubleCodes.net
    Link is for 2012. I don't see the sensor that you are looking for.
    The crankcase pressure sensor in a 2015 Paccar MX13 engine is typically located in the crankcase ventilation hose between the cylinder head cover and the crankcase ventilation module
    Below is a link about the filter.
    PACCAR MX-13 Crankcase Filter: Location, Replacement & More | JustAnswer
  4. Goodysnap
    Goodysnap Road Train Member
    3,748
    9,115
    Jul 12, 2017
    Driver side of the engine. Below the fuel filter module. It’s really not all that easy to see as it is located behind the framerail. The CCV module is on the left front of the engine behind and below the alternator. There is a small pipe off the CCV pressure pipe which feeds the sensor. Best viewed and accessed from the bottom. Not easy to access either.
    blairandgretchen and DonRobbie Thank this.
