Paccar Mx-13 EGR code
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Colth_00, May 3, 2020.
  1. Colth_00
    Colth_00 Bobtail Member
    4
    Truck was running and driving fine. Parked it for the night. When I turned it on the next day fired right up fine but now have check engine seek service light.
    Paccar egr code. Spn 2791 fmi 11. Anyone got any ideas?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    What year truck we talking about?
  4. Colth_00
    4
    Sorry. 2014 peterbilt 389
  5. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    P1515 EGR derate
  6. Colth_00
    4
    What does that mean?
  7. Goodysnap
    3,744
    9,105
    Jul 12, 2017
    It means you have another fault code that is your root cause of the problem at hand. The derate is the result which limits the fuel until the problem is corrected.
    pushbroom and spsauerland Thank this.
  8. Colth_00
    4
    Ok. I also have a VGT code. Spn 2795
  9. Goodysnap
    3,744
    9,105
    Jul 12, 2017
    Too generic really. FMI? The fault Points to VGT position erratic. Many possibilities.
    You need to get to a shop for diag.
    I would start with checking a fuses labeled ECM or engine power supply. Check power and ground supply to VGT actuator and check the resistance of the 120 ohm resistor internal to the actuator. If you have the ability pull the actuator and check VGT sweep. Beware - you need Davie to install and calibrate the actuator if it is removed.
    Good Luck
