Paccar rumored to delete emissions because of parts shortages
Discussion in 'Ask An Owner Operator' started by Cat sdp, Aug 25, 2021.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Wow. You need a permanent fix...
  3. Long FLD
    Long FLD Road Train Member
    12,452
    51,640
    Mar 4, 2015
    It’s a $400 sensor, give or take. They’ve submitted my info to be able to update the software to bypass the sensor when the update becomes available, hopefully on the 15th. Then when sensors are available I’ll have to go in when they issues a recall and get the sensor replaced. I already knew what the problem was when I posted that pic in this thread because once I got all the lights on my dash the def gauge went to empty. The def quality sensor and def level sensor is all one piece so I knew it had failed.
    Every permanent fix I’ve seen on a post 2015 MX13 has been nothing but a hack job with blocked off egr and stuff because nobody makes aftermarket parts like what’s available for the pre 2015 models.
    spsauerland Thanks this.
  4. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Oh yeah? No.
  5. Long FLD
    12,452
    51,640
    Mar 4, 2015
    Nobody makes an aftermarket manifold for the later ones, so you’re stuck using the stock manifold and blocking things off. To me, fixing something right means taking the bad parts off and using better aftermarket parts to rebuild the engine into a better engine
    spsauerland and shooter19802003 Thank this.
  6. Cat sdp
    Cat sdp . .
    21,183
    75,085
    Apr 8, 2012
    Orion's Belt
    A chain around that thing and you would have a great boat anchor…..
    so could you run any liquid in the def tank and the sensor couldn’t tell the difference. Because it’s turned off……….?
  7. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    It's called a mooring, not an anchor.
    Cat sdp Thanks this.
  8. Long FLD
    12,452
    51,640
    Mar 4, 2015
    Could you run any liquid prior to 2016?
    Goodysnap and spsauerland Thank this.
  9. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    No, never. You would destroy the scr
    Magoo1968, spsauerland and Long FLD Thank this.
  10. Cat sdp
    Cat sdp . .
    21,183
    75,085
    Apr 8, 2012
    Orion's Belt
    The factory deleted the quality control sensor they own it……. Just claim you got some bad def…….
  11. Cat sdp
    Cat sdp . .
    21,183
    75,085
    Apr 8, 2012
    Orion's Belt
    Hopefully the chip/sensor problems will go on for years…….
