Paccar rumored to delete emissions because of parts shortages
Discussion in 'Ask An Owner Operator' started by Cat sdp, Aug 25, 2021.
  1. Long FLD
    Long FLD Road Train Member
    12,450
    51,630
    Mar 4, 2015
    Is there any proof that they’re not meeting emission standards without the sensors? They made them run fine without them before.
  3. Cat sdp
    Cat sdp . .
    21,181
    75,060
    Apr 8, 2012
    Orion's Belt
    well if something failed you wouldn’t know it …?
    and if the parts do nothing why are they there in the first place….
    Speed_Drums, jason6541 and TheLoadOut Thank this.
  4. petefan4000
    petefan4000 Light Load Member
    107
    129
    Dec 2, 2020
    I've seen my fair share of them. No matter where you go, there will always be tree huggers, even in places you wouldn't expect.
    But anyways, we're getting off topic here.
    Trucker61016 Thanks this.
  5. Ffx95
    Ffx95 Road Train Member
    1,369
    2,632
    May 18, 2017
    probably void the warranty on the truck. That’s what they were threatening my company with when we had an open recall on the transmissions. I ran a time sensitive dedicated lane and the only downtime was weekends which the dealer around wasn’t open for.
    Trucker61016 and TheLoadOut Thank this.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    The emissions on a 2010 vs a 2022 are exactly the same. The difference is the requirements for HD OBD. PM sensor and UQS sensor were added for OBD, emissions output is the same. A functioning UQS is quicker to identity bad DEF vs Nox sensor readings.
  7. Cat sdp
    Cat sdp . .
    21,181
    75,060
    Apr 8, 2012
    Orion's Belt
    Too bad the geniuses can’t keep the sensors in stock… or keep them from prematurely failing…….
    they suck…. Period. Paccar Freightliner all of them……
    I shouldn’t have to rebuild a new truck just so it will run…….
  8. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Paccar, Freightliner, Cummins.... make neither sensor. Sourced from another manufacturer. Rebuild? Explain....
    Shutting down the country has a lot to due with the current problems.
  9. Cat sdp
    Cat sdp . .
    21,181
    75,060
    Apr 8, 2012
    Orion's Belt
    That’s a problem to they don’t make trucks they just assemble them. Guess they probably went with the lowest bidder to make that sensor in like Singapore maybe……….just in time bits us in the ###-
    Rebuilt meaning that they do everything the cheap way and it takes years to re-engineer the truck to my standards…..
    One example…..They ask why would you want a braided steel line off the compressor….? Who cares that’s what I want so I put it on myself after the fact. I have a long list of stuff like that and engine stuff too…..
    And the truck was ordered by me… all they say is you can’t get this or that etc…..
  10. JayaP
    JayaP Bobtail Member
    26
    5
    Aug 24, 2021
    San antonio tx
    So does that mean Paccar engines or what falls under Paccar sorry .new
    petefan4000 Thanks this.
  11. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Getting to bottom of your pi$$ed offness, ordering new truck blues! Thought you just in dumps with passing of Stones drummer.
    Watch the T800, they are building certain ones in Mexico. Just buy you a 90's hood and rehab it. You will be happier!
