Panasonic radio--buzzing buzzing!
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Stuka, May 10, 2016.
  1. Stuka
    Stuka Light Load Member
    190
    109
    Nov 15, 2013
    Houston, Texas
    My Prostar factory radio had a bad input jack (for the XM radio), so the shop ordered a Panasonic and replaced it. That's good, but now when I listen to the XM radio through the new Panasonic input jack, there is a lot of buzzing, that revs up and down with the engine. I really hate to bug the shop guys again, they will probably tell me there is nothing they can do. Any suggestions? I would take it to a radio shop, somewhere between Houston and Chicago, if I could find one that knows this stuff.
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Buy a better wire with more thick insul. on it an noise should be gone,
  4. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    As stated above-you can run a better wire with more insulation, or you can can install a 12v noise filter on the power wire.
  5. miakica
    miakica Light Load Member
    239
    135
    Mar 17, 2008
    Great White North
    I bet they didn't connect the ground wire....
  6. Stuka
    190
    109
    Nov 15, 2013
    Houston, Texas
    Hi and thanks for the replies. I have more info: I found that the buzzing only occurs using the input jack for the XM radio. USB? CD? FM radio? No buzzing. I can set the source for AUX (which is the XM radio input jack) and the buzzing occurs when the XM radio is on. If I turn off the XM radio, buzzing stops. I'm guessing the problem is, the radio is sensitive and is picking up the noise through the XM radio. I have ordered a PAC isolator like this:
    I will let you know if that works!
    baha and 25(2)+2 Thank this.
  7. Stuka
    190
    109
    Nov 15, 2013
    Houston, Texas
    This worked perfectly~
