Paperless files....
Discussion in 'Ask An Owner Operator' started by Cat sdp, Apr 10, 2015.
  1. Cat sdp
    Cat sdp . .
    20,997
    73,344
    Apr 8, 2012
    Orion's Belt
    I'm technologically challenged to say the least.
    But I'm interested in going paperless with my files. I do everything on truckers report with my I phone and don't ever use my 10 year old desk top. That's going to change I'm getting a scanner and a shredder yippee....
    Has anyone gone totally paperless and do you have any advice....?
  3. mandalorekiller
    mandalorekiller Light Load Member
    119
    22
    Oct 6, 2014
    Your going to need some one to do the paperwork while your on the road. All it comes down to is how you do your paperwork ik that some people use exel and othets just makes folders to put there papers in,i recomend getting a loptop and getting it setup to connect to your desk top it may be a bit expensive to do but you would be able to keep up with your paperwork while on the road
    Cat sdp Thanks this.
  4. Cat sdp
    Cat sdp . .
    20,997
    73,344
    Apr 8, 2012
    Orion's Belt
    I'm home every night so the road isn't a problem.
    But my head does hurt thinking about how to set this program up....
  5. steaburn
    steaburn Bobtail Member
    48
    37
    Oct 10, 2013
    Paris, TN
    It's always a good idea to have backup just in case your hard drive crashes or some other disaster occurs. You can copy everything to a jump drive, use an online backup service, or email yourself a copy of your files each night (assuming you have plenty of storage).
  6. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    My only advice is to organize the paperwork before scanning -- that way the electronic files are in some sensible order...
    TruckerPete1990 Thanks this.
  7. xsetra
    xsetra Road Train Member
    5,119
    6,995
    Aug 21, 2011
    Paperless? As much as I can be. I have a laptop that has Quicken for the Accounting. Acrobat to read and write PDF. Most brokers use PDF for the paperwork. The occasional people that use Microsoft/excel, I use an app on my phone to convert to pdf and than send to my laptop to fill out and send back as a PDF. When I get home I sync with my PC in the house and everything is updated. All the email is accessible from any computer so I don't save to a cloud. My logs are fill in the blank so that is paper I keep.
    Permits I download and print in truck. Not paperless.
    Not that hard to set up. Just buy a laptop with the needed software. Easy. Good luck.
  8. Cat sdp
    Cat sdp . .
    20,997
    73,344
    Apr 8, 2012
    Orion's Belt
    Is there any truck specific software that's better than others..? I just have windows xp.....
    Now I just have paper files fuel, repairs and tolls stuff like that. File everything every couple of days. So it's in chronological order.
    Sorry for the hi tech incompetence ..... Truckers Report is my first exposure to anything on the computer .
  9. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    A Neat scanner works great. You scan it in and you name the file and location. I would also recommend a Cloud Back up service. IRS does not require paper if you have an electronic file, hence the Cloud Backup. You can access your Cloud backup anywhere.
    You can also use Drop Box on your phone, drag your file to it and it puts it in a virtual Cloud and once your home laptop is on, it downloads to your drop box on your computer. Simply a folder.
    I work out of my house using DropBox for files, a Neat Scanner, external drives, and a cloud backup, plus MS Word.
    PM me if you need more info.
    Mark
  10. rollin coal
    rollin coal Road Train Member
    13,300
    26,891
    Mar 29, 2008
    TN
    You don't need any special software. Just a cheap, no more than $100 scanner/printer/fax, and a laptop. Scan your paperwork, rename that file, create a folder and drop it in there. You can get cheap USB zip drives from Wal Mart to transfer those folders to periodically for a backup. With us anymore I've gotten to where I scan practically nothing. I take pics of POD and email those in as soon as I'm empty, somehow or another they print that off and invoice the load. Pic has to be clear though. No need for apps, software or anything. Amazing what you can do with just a phone these days. I probably won't even buy another laptop when my current one dies.
    Cat sdp and Wild Murphy Thank this.
  11. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    For on-the-road scanning you can have a multi-function printer in your truck and/or an app for your phone, or just use the camera (which the scan apps use, but the app will convert pictures to PDF documents). I used both; Cam Scanner on the phone, and a wireless HP printer in the truck (the printer can be accessed with my phone as well). I could send and receive load info, permits, border info and any other required paperwork easily and cheaply (lots of free wifi available so there is no need to pay the usurious truck stop fax rates). Scan receipts, bill of lading, proof of delivery, etc. I could have the proof of delivery in my office within five minutes delivering, even in remote areas, so long as there was cell service available.
    Just set up a filing system on the computer using file folders and file names that works for you... really no different than how you would do it with hard-copy.
    There are a number of free file back-up/synchronization services available (I use Google Drive) which is very nice because you not only have a back-up (can be as current as the last time you turned your computer/device on) of your files, but you can have access from any computer/device (lose yours, get a replacement and be back in business in minutes, or access your account from someone else's computer/device) and virtually any location (on the road and there is a dispute with the office/broker regarding a load in the past? You can access/email it from virtually anywhere).
    Optical Character Recognition (OCR) has also come a long way in recent years. This is important because a number of programs/devices can be used to scan and digitize/sort information on credit card and bank statements, invoices, business cards, etc... even handwritten notes can be recognized and converted to digital format so they are searchable by word(s).
    I also have a very good scanner at home (ScanSnap) for doing higher volumes of paper and/or better quality, digitizing and sorting.
