Parade Driving
Discussion in 'Experienced Truckers' Advice' started by Flying Dutchman, Feb 9, 2011.
  1. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    How many of you have driven a rig in a parade? Specifically pulling a float with people on it??
    It'll be a 2003 Peterbilt 379 3 axle (Spicer 10 spd) pulling a 45' drop deck/flatbed. Not sure if people are standing or sitting, either way, people....unsecured! lol.
    Any tips or advice? My main concern is a smooth ride. Having a 10 spd, I am unable to do button shifts, and am hoping the parade speed is something in 3rd so I can take off and not worry about it.
  3. ratherbtruckin
    ratherbtruckin Light Load Member
    116
    39
    Nov 2, 2009
    Colorado
    I've driven in parades, not a truck mind you. Usually its around 5mph, and as little stop/start as needed. Some turns maybe, depending on where you're doing it. Little town parade I drove in was a long straight run, with a turn on each end to "marshalling" areas. You have to figure "walking speed"
  4. Flying Dutchman
    1,274
    522
    Nov 2, 2009
    Northern California
    I will probably get a rulebook or itenerary of some sort, letting me know the speed limit...never driven the truck before so I will just get a little speed test in each gear so I am aware of where I should be.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    I drove a 1927 chain drive Mack fire truck in a local parade. Had to stop doing it when the insurance and liability costs got out of whack. We hauled kids in the back on benches where the hoses and equipment were originally.
    You'll probably only be in 2nd or 3rd gear on the low side, and still may have to stop and start on occasion.
  6. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    What about driving the thing back? Unless the parade is a circle or something.
  7. Flying Dutchman
    1,274
    522
    Nov 2, 2009
    Northern California
    The float is being decorated by the church I am doing this for, since the trailer is rarely used, I assume we will be parking the trailer at the church parking lot early on the week of, and let it be decorated there. Shouldn't be an issue from there since the church is 2 blocks from the parade route. I assume, once the parade is over, we will be escorted to a staging area where the passengers will exit, and I bring the trailer back to the curch to be un-decorated.
    It's not like the rose parade, I am sure the decor will be not much more than banners and a few props.
  8. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Heck; I thought you was talking about a slow truck in the hammer lane....:biggrin_25523:
  9. EZ Money
    EZ Money Road Train Member
    Me too.....lol!:biggrin_25523:
    No need to remove the decorations...just hit the highway and run her up to about 70.....decorations gone!
    Just joking....that would be a mess!
  10. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,682
    16,196
    Jan 18, 2011
    I've done it a time or two--but w/18--so if I had to I could split a bottom hole(only had to a time or two. I'm assuming the Pete has a higher horsepower motor--which has good torque @low RPM. Without knowing your rear gear ratio--I think your idea of 3rd should do--just walk her out gently on the clutch w/o touchin the gas--should be smooth enough to keep the folks on the trailer nice and secure. I used the high side of 2d in mine both times and actually split it down gently and back a time or two to avoid having to brake. But I have 3:23 so it's pretty tall w/a pumped up 550--but she will pull down below 1000 on a grade(though rarely do it--just being lazy close to top) A lot will also depend on who you are following. First time it was a marching band--so that was easy--kids kept moving pretty well. Next time it was some guy in an underpowered dually trying to pull what looked liked the Queen Mary! LOL--Also depending on who is doing the parade--if there are schedualed stops for performances along the way--there may be marshalls stationed along the way to give you a heads up. Either way--good luck and have fun!
    Just my $.02
    Flying Dutchman Thanks this.
  11. Flying Dutchman
    1,274
    522
    Nov 2, 2009
    Northern California
    Cat C10, unsure of the gearing but if its like my other truck was I should be able to pick up on it within minutes. I didnt even think about who I would follow, you raise good points!
