Parallel Park
Discussion in 'Trucking Schools and CDL Training Forum' started by mvinuela4812, Apr 16, 2018.
  1. mvinuela4812
    mvinuela4812 Bobtail Member
    6
    Apr 16, 2018
    Hello
    This maneuver is giving me a problem cant see to figure it out in school. Any pointers to help Or tricks? This is the death of me this issue lol.
    Thanks
    motocross25 Thanks this.
  3. motocross25
    motocross25 Road Train Member
    3,869
    11,850
    Sep 23, 2010
    Overland Park, KS
    Take it slow is key. Also try to think back on when you’re having trouble, would you say your cranking the wheel one way, then all the way the other and back and forth? Try not to over steer, you’ll have much better luck with smaller steering wheel adjustments, and letting the truck come back around in one motion then trying to serpentine it in there parallel and chasing your trailer back and forth. Just takes time. It’s one of those things that once you get it, it’ll click.
    Digger130 Thanks this.
  4. Powder Joints
    7,949
    8,298
    Sep 25, 2007
    Rosamond, SoCal
    line up the center of your rear tandem tire with the outside edge, turn wheel hard to the lock, back slowly till you see the landing gears in the right mirror, stop turn your wheel all the way to the other lock, start backing, when you get the cab centered on the trailer stop, I forget its been 25 years since I had to do this, but thats a start.
    Digger130 and TokyoJones Thank this.
  5. George_3545
    George_3545 Bobtail Member
    13
    Mar 19, 2018
    Take it easy slow relax . I am not sure if you already have a cdl but if you don't and must take the exam i remember you can get out of your truck 2 times to see the back not sure . So plenty of time and when you get your cdl just take it easy get out of the truck 100 times just make sure your doing it the right way eventually with time comes experience and you will park it like a bicycle . And try not to over steer especially at the beginning of the backing up process
  6. Jwhis
    Jwhis Heavy Load Member
    862
    1,356
    Jan 17, 2018
    Point your driver side trailer bumper at the corner of the box by the curb. Straight back it til your a few feet away from the curb then kick the front end in and pull up a couple feet to straighten out.
