parallel parking procedure
Discussion in 'Questions From New Drivers' started by kerouesque, Jun 4, 2009.
  1. kerouesque
    kerouesque Bobtail Member
    10
    denver, co
    i searched all the threads regarding it and couldnt find anything as detailed as what im looking for. im currently taking the 150 course at SAGE tech in denver. im in my second week, and today i started parallel parking. i had it explained to me and demonstrated, and spent the next four hours practicing. in the first hour and a half, i nailed it perfectly about 3 or 4 times, but as time went on i found it harder and harder to get it right, i was oversteering and not being lined up properly, pretty stressful haha. anyway, to you experienced drivers, can you give me any tips on how you get it in right? particularly when to start turns, where to aim when backing into the space, and any other hints or tips that youve found useful in your experiences. any help is greatly appreciated.
  3. luvtheroad
    luvtheroad Road Train Member
    1,734
    488
    Jan 1, 2009
    Central Ohio
    I know where you're coming from on the longer you do it in a day the worse you get. I had notes that told me every turn of the wheel when I was at school. I couldnt get it for the longest time then all of a sudden it clicked and I was OK. The school I went to was really strict about touching lines and cones. I pulled up so the corner of my trailer was even with the front line then backed watching the cones disappear but your deal might be different. Also watched the landing gear as a visual.
    I have visual problems with the reverse lane change. I'd get half way then would loose concentration on it. OMG did I go nuts on that.
    You'll get it, don't worry and we all have days that are better than others in the backing skills. Good luck!
  4. bubba mark
    bubba mark Medium Load Member
    615
    733
    Apr 9, 2009
    Honestly the best way to learn is to practice. Get out there and play around with it and you will figure it out. It took me forever to learn how to do it. But after a lot of practice I finally figured it out. The more you are in the truck and comfortable with it the easier it will get. Good luck to you.
  5. luvtheroad
    1,734
    488
    Jan 1, 2009
    Central Ohio
    Watch everyone else, find someone who's getting it and ask them about it. That's what I did after I THOUGHT I couldn't do it. You'll get it. Believe me, if I can do it anyone can. Like a previous poster said all it takes is practice after you get the idea. Sometimes it's good to get away from it and maybe they'll let you do some straightline or another skill after you get it a few times. Takes your mind off it.
  6. Rat Fink
    Rat Fink Light Load Member
    190
    122
    Nov 18, 2008
    Lethbridge, AB
    Just look at where the trailer tires are and steer those into place....looking at the lines they are following and correcting as needed.
    Once the trailer tires are pretty much in place, do a final correction of the tractor to get the trailer parallel and the truck straight with the trailer.
    In my opinion if you learn turn by turn, detail by detail you will become a driving robot that can't adapt to anything different.
    When I drove with an instructor he had me line up on his course for doing the parking. he told me to pull upto this one line, and then backup slowly. After 5 seconds turn the wheel and he taught me to use the specific landmarks around the parking lot for making the turns.
    Well guess what? that exact parking lot doesn't follow me wherever I go! Those landmarks aren't there in another province or state. I don't always count 5 seconds before turning the wheel either! That's the point I'm trying to make. Be cautious about following turn by turn directions on a specific course. Real life aint like that!
  7. kerouesque
    10
    denver, co
    thanks for all the replies guys, i appreciate it.
    does anyone happen to know what companies are hiring recent graduates out of denver?
  8. halfburn
    halfburn Medium Load Member
    547
    187
    Feb 22, 2009
    Jasper AL
    After driving for 16 years I do a lot of backing and parallel parking with a daycab and different styles of trailers and its not an exact science. I am happy with the results about one out of three times.
    I would practice in an open space with out the cones until your relaxed then go for the cones unless you are allowed to run over them then I would smash everyone flat the first time and it will be easier from then on. :biggrin_25519:
    With parking (not driving) --
    **It is action and anticipation and expected reaction and not reacting to something unexpected.**
    That means you plan where the trailer is going to go and when it gets to that point you know what you are going to do next. If it does not do what you expected, unless you are positive you know how to correct it you are better off starting over or at least pulling up to get it where you want it and continue. If you are just practicing with no penalty try to get it out of that bad placement to see what the limits are. In the future where there is a penalty of damage fall back to the above.
    Practice and repetition and staying relaxed (rested) are the keys.
    panhandlepat Thanks this.
  9. nikondvr
    nikondvr Light Load Member
    173
    69
    Feb 7, 2007
    You made a statement in your post about "oversteering". That is one of the biggest problems you will face. If you make too big a move in the first place it will require an equally large opposite move to cancel it out. Then so will that one. The trick is when you start only move the wheel one to one and a half turns. Then you can make small adjustments from there. Keep the adjustments small and it won't take much to counter them.
  10. luvtheroad
    1,734
    488
    Jan 1, 2009
    Central Ohio
    You're right, real life isn't like that. But when you're in school and learning the backing skills your world is yellow lines and cones. You are taught not to touch a yellow line or knock over a cone. They are teaching you to pass the CDL exam not to do backing in a real life scenerio. It's all about passing the exam and then the school leaves it up to the trainer at your new place of employment to teach you real life.
  11. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    if you are allowed to...
    STOP before you make each of your wheel turns.
    it gives you a second or 2 to think about it
