Parasitic drain issue.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by angelor, Jun 4, 2013.
  1. angelor
    angelor Bobtail Member
    40
    May 22, 2013
    I am at my wits end. There is something drawing juice from my batteries on a 2007 freightliner M2. I have pulled each fuse 1 at a time and sparks still fly when reconnecting negative cables. I did the same with all the relays behind dashboard. When I jumped truck to get started all lights started flashing including 1 headlight. Could not get any of them to turn off. Trying to find fuse for emergency lights. Would the solenoid or IMS on the starter be drawing juice if faulty? There is only 3000 hours on this truck. It has a heavy machine mounted on back and has never been above 25 m.p.h. Last time I had mechanic out here, it cost 1000 for his 1.5 hours to tell me what I already knew.
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Have you disconnected and cleaned all main grounds including the chassis grounds?. Sounds like a corrosion problem meaning the grounds corroded and drawing power from other circuits. How much parasitic drain?. Disconnect main pos cable and use a dvom set on amperage and place one lead on pos trminal of battery and the other on pos cable. Read the amt of amps being drawn. Be sure all circuits are switched off. Think you are going to find out you have some serious corrosion problem on ground circuit.
    angelor Thanks this.
  4. angelor
    40
    May 22, 2013
    I am having nothing but corrosion problems with the whole fleet. There is no salt allowed here, so I don't understand it. I have changed so many bulbs AND SOCKETS due to melting on the front turn signals on every truck we have. I will do what you say and get back later in the day. Thank you so much!
  5. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    If that is the case you need to be putting dielectric grease on all bulb sockets. Find all grounds engine grounds chassis grounds and remove fasteners and wire brush them really well then use a protective coating also check your charging system is alternator putting out right voltage/amps?. Connections clean and tight?. Also check connections at starter clean and tight?. Have you done a voltage drop test from batts to starter?. If more than about half a volt drop then you have battery cable with serious corrosion inside under the insulation
  6. angelor
    40
    May 22, 2013
    Yeah I already bought every package of bulb grease they had in anticipation of this. I couldn't believe fuse did't trip. I don't have an ampmeter yet, but I used my powerprobe and it shows a draw of 7.8 volts! The ohmeter showed a negative couldn't get a reading. Alternator good. Another problem we are having with all these trucks is the wiring is coming up too short over time and things are getting pulled out by themselves. 4 heaters last winter alone. You would think Mercedes and freightliner would spend a nickel for 1 more inch. Recalled trucks due to PLASTIC fuel lines. Thank God for on-the-job-training. Going back out there and removing all the grounds and cleaning and greasing them then I will do the volt drop test. Thanx a million.
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Does your truck have the mega fuses under the drivers side rocker panel? That was a big problem area on our Freightliners, but they were Cascadias, not M2's. Little red box with 3-5 mega fuses in it. Every one I've opened was full of green. We also had a lot of issues with the trailer module corroding up, which was mounted next to the driveshaft.
  8. angelor
    40
    May 22, 2013
    yes there are 3 I only checked the easy ones. One was burnt. Now I will check the rest. I pulled starter and am in process of getting it tested. It wouldn't turn on when I hooked to battery in van. Just for ##### and giggles I reattached negative cable to battery and I still got a spark and 7.8 volts drain.AAAARGH. This was with starter out and door closed. I don't think there is low-battery thingamagig.
  9. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    It sounds like you have a dead short somewhere.
  10. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    It sounds like you have a dead short somewhere. Check for hot wires.
  11. angelor
    40
    May 22, 2013
    Do you mean check negative wires for volts, or positive wires being grounded?
