Parked regen
Discussion in 'International Forum' started by HammerDownISX, Nov 3, 2014.
  1. HammerDownISX
    HammerDownISX Bobtail Member
    18
    4
    May 4, 2014
    Chicago IL
    I had a level 1 warning I am doing a parked regen now but it's been going for 1 hour and 20 mins is that normal I have a 2010 international prostar ISX motor
  3. Inland-Pilot
    Inland-Pilot Light Load Member
    229
    135
    Jun 23, 2010
    Jackson, Ms
    I don't think that's normal at all. Good luck!
  4. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    Negative Ghostrider....Parked regens usually last right around 45 mins give or take. Get it checked out & good luck....I have yet to run across ANY issues with the new DPF/post-new emissions engines that were either easy to diagnose/fix or cheap.
    *mutters under breath about stupid EPA BS*
    BigJls1 Thanks this.
  5. kenszo47
    kenszo47 Light Load Member
    55
    17
    May 21, 2012
    DELAND,FL
    No problem. I had a '12 pete that was still in regen 6 hrs later cause I fell asleep. The electronics on these have there faults. A parked regen would never be needed if the system worked correctly and regen'd when running as designed. My pete would lose speed ...say from 62 down to 50 and if I didn't pull over and do the parked regen would then have a top speed of 40 forcing me off. It's in the computer and no mech/tech wants to hear about it. Most are trouble free, you got a bad draw.
  6. d4rk
    d4rk Bobtail Member
    9
    It will last up to 75 min there is no issue make sure you have ecu up to date it will fix temp issues during stationary regens
  7. d4rk
    d4rk Bobtail Member
    9
    The ecu wants to see temps of inlet doc 600° dpf in let 900+- outlet within 100° of of inlet if the HC doser is dirty it will have a hard time reaching proper temps how many miles on her?
  8. marek4792
    marek4792 Light Load Member
    62
    31
    Mar 21, 2011
    Chicago, IL
    assuming your truck was doing a Regen while driving before pulling off, engage the parked regen wait like 15 mins then cancel it. By some dumb luck it would clear the dpf light and i wouldn't have any further issues. i drive a 2013 prostar with a maxxforce.
