Currently on a home search, one of my requirements (which is partially limiting my search) is being able to get the truck and trailer in (or at least the land/space so i can) while fully loaded.
For laziness i THINK i would like a big peice of flat land, then just make a big wide gravel circle, maybe concrete pad for where i finally park (flatbed spread axle and long wheelbase)
Any of you care to share a satellite/overhead view of how you do it?
Parking at home with the trailer
Discussion in 'Ask An Owner Operator' started by skallagrime, May 9, 2022.
Page 1 of 3
I rent a spot in a secured lot. Or at least it’s under surveillance by the Italians that own it
Somehow someone shows up every time I buy a new truck within minutes
But
That said make sure wherever you buy land that it’s ok to park there
Some cities have rules that you can’t do this or thatskallagrime, Flat Earth Trucker, tscottme and 2 others Thank this. -
Yep I am in the same boat. Hope after next summer I can get enough put back to get a different place. That is my main reason for wanting to get a different home. Need a place to park truck and trailer where people cannot mess my stuff up. I have had my trailer hit twice now where I park with no one accountable for it.
skallagrime Thanks this. -
Typically not available if you're anywhere near a community with an H.O.A.
skallagrime, Flat Earth Trucker, JoeyJunk and 11 others Thank this. -
Dont have a picture handy and on sat view its covered by the tree anyway. But i just park beside my friends combine in the dirt or on the strech of road we basically own. Just turn right at the crossroad back up to the east side then turn back the way i came and back right on into our yard.
skallagrime and GYPSY65 Thank this. -
I have to pull in and make a u turn in my yard. Works ok with the tandem closed empty. Kinda works if im loaded with the tandems closed. No joy with the spread open and loaded. I got 13 loads of rock in a couple weeks ago to put in a second entrance and a drive around.
larry2903, skallagrime, cke and 6 others Thank this. -
Can do it now. I used recycled asphalt. But that dirt gets REAL soft when it rains. So need a hard surface. -
cke, JoeyJunk, D.Tibbitt and 1 other person Thank this.
77fib77, Flat Earth Trucker, JoeyJunk and 5 others Thank this.
skallagrime, JoeyJunk, D.Tibbitt and 2 others Thank this.
Page 1 of 3
