parking brake warning light and buzzer
Discussion in 'Volvo Forum' started by Cluck Cluck, Aug 21, 2014.
  1. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    I'm having an issue with my parking brake light and buzzer.
    So while I driving down the road my buzzer goes off along the the red triangle and the little red circle with a P inside warning me that my parking brake is applied. Although I know it's not.
    I pull over set me brakes and the red triangle disappears I check for codes. None.
    So I release my parking brake drive down the road a little farther 60 miles or so and it does it again. I repeat the same steps and again it all goes away.
    It seems that the truck thinks it's in park and it's not. Is there anyway to get around this malfunction? Do I have a short somewhere?
    2011 vnl630 with a volvo engine.
    Service shop says they've never heard of this happening.
  3. d{xx}b
    d{xx}b Bobtail Member
    4
    Canada
    I had the same problem on my vt 830 I used to have and the volvo dealer i stopped by then replaced the parking brake switch, switch did cost less than 30$ and is mounted near the brake pedal
    hope that helps
  4. Bentig
    Bentig Bobtail Member
    Same problem here 2011 vnl64t300
    just unplug the sensor located behind the lower left kick panel. Switch wire is labeled "PBS"
    that will tell the computer that the park brake is not engaged.
  5. Safety First Trucker
    Safety First Trucker Bobtail Member
    2015 Volvo VNL 670 - I had a brake switch fault code. I purchased the switch, and had a Nextran dealership replace it. When I came to pick my truck up park switch fault code going off. Truck won’t drive. Their response is by replacing one switch another could in turn go bad and have to be replaced. But they have to charge diagnosis with this. Thoughts?
  6. VolvoD13_16
    VolvoD13_16 Bobtail Member
    I have the same problem. It buzzes while driving. After replacing parking brake switch it is still buzzing when i start driving. Has anyone had this issue before? Any info helps at this point
