If I have someone who works full time 70 hours a week in shop, drives locally. How do they record their on duty time? Do they need to show all breaks and their driving locally or can they just put a line through on-duty as long as the driving is less than 100 miles?
Part-Time Driver Logs
Discussion in 'Questions From New Drivers' started by tlg025n, Oct 30, 2013.
Unless things have changed, you don't have to run a log as long as you travel less than 100 air miles from your home terminal. If you locate your terminal on a map, and draw a circle around the home terminal at a 100 mile radius, then if the driver never exceeds that distance, he doesn't need to log it.
Time cards suffice for short haul
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=395.8rwdfinch50 Thanks this. -
CondoCruiser Thanks this.
If the driver drives out of the 100 air miles every so often tho (once a month), does the driver need to show on his 7 previous logs the local driving he did on the status line of driving time or can he log all local driving and shop time just as on-duty not driving? And also does the driver need to have 7 days logged after his long trip out of the 100 air miles?
