Part time job?
Discussion in 'Questions From New Drivers' started by Schshark2, Jan 24, 2017.
  1. Schshark2
    Schshark2 Bobtail Member
    Hello, my question is it worth it to try and start up a small hot shot load company? I'm a firefighter and currently work 24hrs on 48 hours off. I wanted to buy a one ton truck and trailer and start hauling loads. Is this a good idea? Also is it hard to stay in the same state (Illinois) and be home at night? I want to make use of all my off time.
  3. Eddiec
    Eddiec Road Train Member
    2,262
    3,476
    Feb 2, 2015
    I am a retired Firefighter and I hauled containers on my days off (24/72), so yes it can be done. You just have to make the right connections and determine if the risk vs. reward is worth it.
  4. Schshark2
    Did you use load boards online or did you make connections with companies?
  5. Eddiec
    2,262
    3,476
    Feb 2, 2015
    I leased on with a company, they were very flexible.
  6. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    Be careful about your hours of service. You have to log On Duty for any other non-driving job. If you work 24 hours on your other job, you need to log 10 hours off duty before starting your driving shift. It may mean on a 24/48 hour work/off duty schedule you might not be able to legally drive if you chewed through your 70 hour clock.
    It could all look pretty on paper, but if you get hit by a careless civilian and they lawyer up, you could be in for bad times if they find out you have two jobs.
  7. Eddiec
    2,262
    3,476
    Feb 2, 2015
    "The risk"
  8. Lepton1
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    If by your quotation marks you mean to minimize the risk...
    ...don't
    I have a perfect driving record. However, I did have an incident last October when a civilian ran into me in a construction zone. I had dash cam footage. I had clean logs. The LEO cited the civilian. The civilian lawyered up, but after a quick check of my logs they quickly went away. If you aren't supposed to be there, then that is automatically on you. Not even sure if your insurance would go to bat for you in a lawsuit.
    Working a CDL as a part time job? Then you had better be clean on your logs.
  9. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    You could hire onto a in city courier company. Flats get better pay than cars, vans, or box trucks. You call in the morning, tell em you active, and wait for work. Kinda like uber for freight..
