Parts needed to hop-up a Cummins Big Cam
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Davo81, Feb 19, 2013.
  1. Davo81
    Davo81 Light Load Member
    64
    15
    Aug 5, 2011
    Melbourne, Australia
    I've heard big cams aren't great on head gaskets (mainly from cat guys), so how do that Pittsburgh mob keep their big cams together?
  3. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    My guess is not for very long if they are using all the HP the engine can produce. Head walk, deck grooves, cracks from head bolts to liner bores, broken crank, are all very possible, and probable, on high HP Big Cams.
  4. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Except if it does have the 17.1 pistons in it a cam change is required as well to match up with the 14:1 pistons. Most like if it is a high comp engine the timing is set at .117 or some where close to that, to make it live he's going to have to possibly change the timing and maybe even the cam.
  5. Davo81
    64
    15
    Aug 5, 2011
    Hmmmm, so the old big cam isn't such a great engine? What's a safe power for them? 450?
    I'm guessing you're going to tell me a 3406 is a much better, more reliable engine?
  6. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    Yes the 3406 is.
    If/ when you change the pistons, the lower compression will help the longevity. I myself have never popped a head bolt or blown a head gasket.
  7. Davo81
    64
    15
    Aug 5, 2011
    You mean you've never done a head bolt or head gasket in a big cam or a 3406?
    this is the first time I've heard that the 3406 is better then the big cam!
  8. Diesel Dave
    8,718
    24,952
    Jan 20, 2010
    Hesperia, Ca.
    You will NEVER, EVER go wrong with a 3406. I to own a BC1 cpl369(its parked) and it was hop up, Over 300 psi on the full pump, oversize injectors and a Holset HT4b turbo. But compared to my 3406, its like not and day in favored of the 3406
  9. Davo81
    64
    15
    Aug 5, 2011
    I guess it depends who you, because I've heard the complete opposite as well! I like the 3406, but they're pretty rare here in Oz, where as Big Cams are every where!
  10. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    Nope, I run around 60 psi of boost on my 3406B and its still holding, even had nitrous on it at one time. My big cams havent seen that sort of boost, but i know of a couple that have and the head gaskets are still holding strong.
    Compression is a big factor, my 3406 is 14.5:1, one of my big cams is 13.5:1, and the other has 14.5:1 pistons in it. If the timing is set to match, they can be made to live, Im just not sure how long at 650 hp.
  11. Davo81
    64
    15
    Aug 5, 2011
    Would 500-550hp be be safe?
