Parts needed to hop-up a Cummins Big Cam
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Davo81, Feb 19, 2013.
  1. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Nope, just an idiot who over heated it before I bought the truck.
  3. Davo81
    Davo81 Light Load Member
    64
    15
    Aug 5, 2011
    Melbourne, Australia
    Will water injection help? I have no problems running it...
  4. western diesel & performa
    western diesel & performa Bobtail Member
    10
    Nov 7, 2012
    hey davo your engine by the sounds of it should be a big cam 4 with cpl 905 if it is the 320 hp which is not an stc engine like the 444, you will need to change pistons for compression ratio, fuel pump turbo , ###### cam timing but are best off replacing cam to a high lift for the hp you are looking for.
    i m from sydney pm me if you like i may be able to help you out
    jamespmack Thanks this.
  5. Davo81
    64
    15
    Aug 5, 2011
    While I wait Western Diesel to call/reply to my PM, does anyone else have any input?
  6. Davo81
    64
    15
    Aug 5, 2011
    It appears to be a CPL905
    Intothesunset Thanks this.
  7. Easy1983
    Easy1983 Bobtail Member
    6
    Feb 9, 2019
    I need your advice on my Cummins fuel pump and I hear your the best SmokinCat
  8. Easy1983
    6
    Feb 9, 2019
    Let's talk Cummins I need your help
  9. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    Pretty simple, find a reputable shop and tell them what you want.
    Call it what you want but I am very weary of giving people the know how to change a pump blindly and then thinking that I told them to do something wrong.
    I'd rather see someone go up in flow on injectors and never touch the pump at first, cranking the pump is hard on cams.
    Oxbow and OLDSKOOLERnWV Thank this.
  10. MACK E-6
    48,937
    226,917
  11. OLDSKOOLERnWV
    18,360
    276,354
    Sorry just seen this....
    I agree with @SmokinCAT , he is correct. Adding fuel pressure to the injectors adds pressure to the cam lobes, only a matter of time till the Hardmetal starts flaking off the lobes.
    Bigger injectors will help, without adding pressure to the cam lobes.
    Oxbow and MACK E-6 Thank this.
