Parts that require programming at dealer
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Arky, Dec 29, 2023.
  1. Arky
    Arky Heavy Load Member
    858
    588
    Jun 7, 2013
    Hello, I have a local mechanic that I prefer to do my work but he tells me that so many of the newer year model trucks have parts on them that require some kind of dealer programming to be functional. I've found enough just on Google and search here to believe that is an issue for non dealership mechanics.
    So I have a few questions for those of you familiar with later model trucks... I am not.
    1. About what year did this begin? I am mostly interested in Peterbilt, KW and FL trucks. Cummins or Detroit engines.
    2. Is there any work around to getting these parts programmed? My research tells me the answer is no?
    I would like to buy newer trucks but I wa t my mechanic to work on them not the dealership. It's not about emissions.. it's about who I want working on my equipment.
    Thanks!
  3. Goodysnap
    Goodysnap Road Train Member
    3,772
    9,198
    Jul 12, 2017
    Your mechanic needs to get OEM tooling /programs and service information for your trucks. The information and tools is not limited to dealers, they are just the ones that are mandated to have them to fully support the brand.
    There are a lot more components on a truck that need programming or calibration to install than ever before that’s for sure.
    Big Road Skateboard and Arky Thank this.
  4. Arky
    858
    588
    Jun 7, 2013
    Thank you, that helps a lot. I'm going to educate myself on this topic as much as possible.
  5. Long FLD
    Long FLD Road Train Member
    12,874
    53,885
    Mar 4, 2015
    Your mechanic can get the software. A friend of mine runs a mix of Cummins and Paccar engines and has the software to recalibrate everything when sensors get replaced. I think his trucks still have to go to the dealer for any software updates though. I’m not sure what all they can do with the software he bought.
    Arky and Big Road Skateboard Thank this.
  6. Goodysnap
    3,772
    9,198
    Jul 12, 2017
    I’ve worked both sides of the fence. From the independent side it is very expensive to get the programs for only a few times a year. But if you have the work load, it’s the only way to go. Very hard to cover all makes and be universal.
  7. Arky
    858
    588
    Jun 7, 2013
    Does anyone happen to know what year model this started in? I might be satisfied with just upgrading to a certain year
  8. sirrepairsalot
    sirrepairsalot Light Load Member
    66
    28
    Aug 9, 2018
    Canada
    It all depends on what systems you are talking about and which manufacture. I remember back in 2008, working on a Prostar with a Cummins & I had to send it out for a simple Forced Regen, Nowadays, most Data Link Style Programs will work to force a regen, however without it forget it. Then International with their BS started hooking up modules for everything from switches on the dash to aftertreatment devices to individual modules and had to be scanned and modifications done by their software.. Nowadays, I'm sure every manufacturer has something on board a truck that needs some kind of specialized tooling, everything from an injector change out and the calibration code to be programmed, to a body control module that unlocks your doors. The way it goes is your truck say came with power locks and windows and another one didnt it wont recognize, or output commands to that particular module or actuator until the programming inside the module is programmed to actually do those functions. Its got to match the VIN and specs of the truck its installed in, and they usually come blank. You MAY get lucky installing a used one exactly the same but they are getting pickier and pickier... Trial and Error, but I'd Say Year 2002 would be the year that things started getting difficult.
    Arky Thanks this.
