Passed a scale.
Discussion in 'Experienced Truckers' Advice' started by VolunteerTrucker, Jul 26, 2016.
  1. VolunteerTrucker
    VolunteerTrucker Light Load Member
    163
    101
    Dec 8, 2014
    EDIT: Nothing more to see here. Delete if necessary
  3. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
  4. AModelCat
    162,453
    The thing that worries me most is that you felt it was ok to just roll out with a possible brake problem.
  5. tucker
    tucker Road Train Member
    12,647
    40,424
    Jun 13, 2008
    IN
    Wmt... You got lucky this time. I bet there's another scale on your route.
    Try unhooking your air lines and sliding your tandems, or back up to a tall curb and use that as a chock, just be sure to lift your mud flaps up so you don't rip them off
  6. freightwipper
    freightwipper Road Train Member
    9,366
    11,439
    Mar 24, 2014
    OTR
    Overweight and no trailer brakes = hammer down :cool:
    dog-c, Dominick253, Hick and 3 others Thank this.
  7. Hudson_MacBeth
    Hudson_MacBeth Medium Load Member
    350
    397
    Sep 3, 2015
    better yet, go to a shop and get the trailer brakes adjusted.
    Dominick253 and CrappieJunkie Thank this.
  8. VolunteerTrucker
    163
    101
    Dec 8, 2014
    I knew the brakes worked fine. I picked the trailer up in Texas and drove to KC with no stopping issues. The load on it was only 20k so I didnt need to worry about moving the tandems on that one. I drove back to the shipper (only a mile away) and tried using one of their rubber chocks . That didnt work , they were too small
  9. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    The red lights are recorded.
  10. Hudson_MacBeth
    350
    397
    Sep 3, 2015
    The brakes did NOT work fine. if the round rubber things turn when the brakes are set, then the brakes most definitely are NOT working fine
  11. wore out
    wore out Numbered Classic
    16,906
    207,539
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Bad trailer brakes, and you worry bout a ticket in the mail. SMDH
