Passenger Side tail lights not working bobtail only Freightliner Cascadia 2015
Discussion in 'Freightliner Forum' started by Nurzat1993, Feb 17, 2019.
  1. Nurzat1993
    Nurzat1993 Bobtail Member
    5
    Hello trucker brothers! Need Help
    Passenger side tail lights not working but all other functions works (turn, stop, flashing lights) only parking lights not working try connect wire from driver side everything works good Please!!! Let me know if was same problem
    Thank you!
  3. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    Check the fuses in the SAM chassis module.
  4. Yo_ItsShreq
    Yo_ItsShreq Bobtail Member
    What ended up fixing the problem? I'm having the same issue
  5. Rideandrepair
    17,426
    56,529
    Aug 8, 2015
    Check the pigtail to the light. 1 of the 3 wires is probably broken. Starting at the light,the plug itself.trace wires back till you find a break. A test light will be handy, if you can’t see the break. You can unplug the working light, use test light on each prong of the plug. Compare results to the non working plug. It’s usually a bad red or white wire, If I recall. Blacks usually ground.I may be wrong, test light will tell.
  6. Jldfreight
    Jldfreight Bobtail Member
    Feb 20, 2020
    Had the same problem both sides eventually replace all the wiring to the plug mounted on driver side rail. Broken and corroded wires
    Rideandrepair Thanks this.
  7. Megamind99
    Megamind99 Bobtail Member
    Having same issue no bad wires at all what do indo
