Passenger window went down on its own and won't go up
Discussion in 'Volvo Forum' started by ryan7892, Nov 8, 2014.
  1. ryan7892
    ryan7892 Light Load Member
    123
    45
    May 11, 2013
    Maryland
    Well the title says it all. I started the truck and was sitting there with the driver door open and the passenger window went down while not touching anything. I have no codes in the dash. It's a 2009 volvo 670. Has anyone have this happen before. I checked the fuse but don't know if or where the relay may be. Any help? Thanks
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Pop out the pass. side window switch on drivers door panel ck. if still has wires pluged in, then try pass. side switch to make pass. window go up.
    OPUS 7 Thanks this.
  4. Edgar2191
    Edgar2191 Light Load Member
    178
    33
    Apr 9, 2013
    Hes right mine does it to.
  5. Leather Helmet
    Leather Helmet Light Load Member
    63
    27
    Nov 1, 2014
    Charlotte North Carolina
    if trucks have cable type window regulators its probably a broken regulator, I have replaced hundreds....
  6. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Sounds like the switch is shorted out for the down position. Do what baha said above.
  7. OPUS 7
    OPUS 7 Road Train Member
    1,124
    1,010
    Aug 13, 2010
    404
    I had that happen too.Stupid volvos..
    I could get mine back up,but it would immediately override,
    and go back down.It finally stopped,but scared me,cause it
    was cold.Maybe try to cut power,and see if responds,after reconnect in.
    Last resort,try to slam the door,and hope for a jog sets it right.
    Good luck
  8. TexasPhoenix
    TexasPhoenix Medium Load Member
    540
    329
    Jul 16, 2009
    Wisconsin
    Had the same problem. It was raining when the window went down. Scarred the cat who rides in the passenger seat. Had to replace the switch. Moisture was the problem.
    Skate-Board Thanks this.
  9. Knucklehead619
    Knucklehead619 Medium Load Member
    537
    591
    Mar 11, 2014
    Flyover Country
    It's the switch. Whether it's the d/s or p/s switch you may need to experiment. Had this happen to me several years ago in my old lease truck (2010 VNL780). The d/s (which has both switches) went on mine... Figured it out when I disconnected the p/s and still couldn't get the window back up. Disconnected the d/s switch and voila the p/s brought he window back up. I wound up pulling the fuse so the window wouldn't move at all and bought a new switch from the dealer. 260-ish bucks for the new one.
  10. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    door control unit is a small electronic board with window motor driver MOSFET. It may fail. To be sure swap pass side and dr/ side door units (just pop out with knife) and try. If works - change unit ore this MOSFET if not - check voltage supply of door unit, may be wires are broken in place they are bent. else... fix motor
  11. ryan7892
    123
    45
    May 11, 2013
    Maryland
    Thanks for the insight. The window went up later on then. But I'll remember this for when it does it again.
