Passing CDL test for Class A in a Dumptruck with air brakes and electric trailer, IL
Discussion in 'Questions From New Drivers' started by ichudov, Mar 19, 2012.
  1. ichudov
    ichudov Heavy Load Member
    742
    641
    Mar 14, 2012
    Berkeley, IL
    I finally got a hold of the test facility. They told me that if the vehicle has air brakes, and has a more than 26k capacity, it is OK to have a suitable electric brake trailer and I will not have tractor/trailer or air brake restriction. Also, they said, the trans (automatic or not) does not matter.
  3. MNoutkast
    MNoutkast Medium Load Member
    441
    151
    Feb 24, 2012
    Elk River, MN
    Thats the way it is here in MN....many places rent out very small flatbed trucks with airbrakes and auto transmissions with short bobcat style trailers.
    One testing facility actually recommends you do not use a full size tractor and trailer because of the size of the streets on the course.
  4. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    383.95 (d) (d) Tractor-trailer . If an applicant performs the skills test in a combination vehicle for a Group A CDL with the power unit and towed unit connected with a pintle hook or other non-fifth wheel connection, the State must indicate on the CDL, if issued, that the person is restricted from operating a tractor-trailer combination connected by a fifth wheel that requires a Group A CDL.
    Best regards
    Roadmedic Thanks this.
  5. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Interesting.
    Still have never seen them do this.
    Does not affect me, I have the full thing and all endorsements, except let the hazmat go again.
  6. dibstr
    1,308
    932
    Sep 10, 2010
    They are incorrect as the auto transmission does cause a restriction.
    383.95 (c) Manual transmission. (1) If an applicant performs the skills test in a vehicle equipped with an automatic transmission, the State must indicate on the CDL, if issued, that the person is restricted from operating a CMV equipped with a manual transmission.
    But on the other hand if they do not put the restriction on, I guess that's between them and the feds and no skin off of your nose.
    Best regards.
  7. MNoutkast
    441
    151
    Feb 24, 2012
    Elk River, MN
    It is very odd that there are restrictions in the FMCSA Regs that are not in forced at the state level. MN does not indicate either restriction on their license, I tested with an Auto and a pintle.
    ichudov Thanks this.
  8. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    So, you tested with an auto and a pintle, same as my setup, and you received a class A CDL without restrictions?
  9. MNoutkast
    441
    151
    Feb 24, 2012
    Elk River, MN
    Yes sir it was the cheapest route to go about it. Ryder wanted my left leg and first born to rent a tractor and trailer to test in.
    Actually this is the exact truck I used:
    Class A with out airbrakes:
    As you can see MN is way to relaxed on what you test in. IL may not be so easy going.
  10. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    Wow!
    If I did not care about the air brakes restriction, I could just test with my pickup truck and my 20,000 lbs trailer!
    But, I think, I would rather spend $300 and test and get a unrestricted class A.
  11. abyliks
    abyliks Road Train Member
    3,892
    9,102
    May 2, 2010
    ludlow MA
    ive known people that have both tested in autos and used 20 ton tags and a dump to get there license and are unrestricted, im pretty sure they got rid of those in the 90s.
