Been working on my truck and the pdl light came on idont know where the switch is for it it's old 88 or so dt 366 5speed with a spliter sigle axle
Pdl light
Discussion in 'International Forum' started by Gweets, Oct 19, 2016.
My Internationals are a little younger than that but It should be there somewhere. If you can't find it may have to call a dealer.
Do you mean the switch on the diff, or in the cab? In the cab should be below the steering column/ center dash, area along the same bar that the key switch is on.
PDL is power divider lock for twin screws, two drive axles, and locks the front and rear together.
Does it have and axle lock, single axle type, and or air brakes.
Probably an electrical gremlin.pigeon river trucking and Heavyd Thank this.
