Peak Tornado Month About to Begin in May
Discussion in 'Truckers' Weather & Road Conditions' started by STexan, Apr 26, 2018.
  1. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    May is usually the month with the most destructive tornadoes in the US. And long term forecasts show May 1 and 2 might ring in some south-central plains action. Keep aware of what's going on and what you're heading into or what's coming your way. Keep your head on a swivel when things start looking dicey.
    Often when these things are showing up in SPC forecasts this far out, they usually begin to increase in threat risk as the days draw nearer
    Eowyn Thanks this.
  3. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
  4. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I love to observe discreet nighttime storms passing nearby
    From SPC's web site. Wednesday might end up at least a "Moderate Day" by game day
    On Tuesday/D5, heights will rise across the central Plains as a
    larger-scale upper trough amplifies across the Southwest, and in the
    wake of the departing upper MS Valley wave. A few severe storms
    cannot be ruled out across MN into WI, but instability will be
    marginal. Southerly winds will continue across the Plains, featuring
    a more robust moisture return with mid 60s F dewpoints into OK and
    then KS late, and uppers 60s to near 70 F into central TX. Even
    through instability will be greater, the area will be in between
    waves, which typically results in very isolated daytime activity,
    and a greater degree of nocturnal storms associated with warm
    advection. The area from northern KS into southern NE, southwest IA,
    and northwest MO appears to have the greatest threat of
    evening/overnight storms, and instability may be strong enough for a
    few daytime cells, and/or an MCS.
    On Wednesday/D6, the severe threat should be more widespread as the
    main upper trough moves into the Plains. Low-level moisture will be
    firmly established with mid to upper 60s F dewpoints east of a
    dryline extending from western KS into northwest TX by late
    afternoon, with a warm front/outflow somewhere across northern KS or
    southern NE. Early day storms will likely play a role in the severe
    setup, both in terms of air mass quality for northern areas, and
    possible outflow boundaries. Models do hint at storms forming
    relatively early across KS, with more of a diurnal threat along the
    dryline. Wind profiles will favor supercells in all areas, but storm
    mode may be more complex away from the dryline. A few tornadoes,
    damaging wind, and large hail are all possible. This severe area for
    Wednesday/D6 will likely be adjusted spatially in the coming days.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,767
    Mar 5, 2012
    Ontario Canada
    Weather channel is showing lots of possible tornado activity tonight for the plains and Midwest- looked like central Oklahoma up through Kansas and Missouri all the way up to Michigan. Worth keeping an eye on if you're in the area tonight/tomorrow.
