Performance mods
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Donk, May 19, 2008.
  1. Donk
    Donk Have a Cup Of Concrete
    1,643
    9,232
    Apr 27, 2008
    After reading the pitsburg power pages on hot rodding older cummins engines, i was wondering if anyone has similar links to do the same/ similar to the electronic engines from all 3 MFGs. ( i'll include the 3406 family in there too ).
    If anyone could help i would appreciate it.
  3. 25(2)+2
    18,756
    45,823
    Sep 18, 2006
    the road less travelled
    They make the power computer for electronic engines from Cat, Cummins, and Detroit, I don't know about the IS Cummins series, or the newer Cat and Detroit, Detroit was up to DDEC IV I think,for the computer, and the newer engines are harder to modify. Currently, Detroit is up to DDEC VI on all the Series 60 and Mercedes Benz, and the new DD15.
  4. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    Dont get a pitts box, there are safer ways to make power. The box will eventually melt your motor down. But they do make them for acerts, and ISX now from what i hear.
  5. Donk
    1,643
    9,232
    Apr 27, 2008
    I wasnt reffering to their box, more their tech articles to making power on the older engined. as in changed timing and etc..
    just wondering if there is any info like that available for the electronic motors as when i do get back into another rig, i will hotrod it.
  6. 550hpW900L
    1,874
    1,090
    Jan 29, 2008
    norcal
    I can tell you all you need to know, my 2003 C15 i over 1000hp at the motor. As far as CAT goes, i know some high power detroit guys as well. I dont really care for cummins, but most cummins guys use the box.
  7. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    I figured you'd be all over this post. lol
  8. Donk
    1,643
    9,232
    Apr 27, 2008
    i will keep it in mind for when the time comes.. Thanks
  9. 550hpW900L
    1,874
    1,090
    Jan 29, 2008
    norcal
    Its my forte :yes2557:
  10. Donk
    1,643
    9,232
    Apr 27, 2008
    Feel like sharing anything? just cause im bored now waiting for a quote to bring my rig up for its roadworthiness inspection, no looking good and its needed for the sale.
  11. 550hpW900L
    1,874
    1,090
    Jan 29, 2008
    norcal
    Well its a 2003 C-15 "bridge" engine rated at 525hp 1850tq from factory. I started out with a fuel temp wire, then swapped ecm's to a pre emission 6NZ with marine porgram, added a boost sensor wire. Then from there i got a 3406E 800hp camshaft and injectors, with a big michigan turbo special stage 5 turbo. I ran it like that for a while, now i recently installed a C-16 CAT ecm with 2300rpm program, FLS or full load setting is set to 127 in the ecm, meaning the fuel map is pretty much maxed out, this ecm cannot give any more fuel without bigger injectors. Also injector trim codes are set to 5232, anybody can change the trim codes and this is the "hot" code for all single turbo 6NZ and older Caterpillars, worth 60hp over stock. Thats how i am running mine right now. This is achieved with all factory Caterpillar parts, i will run across a 6% grade doing 75mph with a full load in 17th gear, i could do it in top gear but rpms are to low and the exhaust temps get a tad warm, so i keep it around 1700-1800rpm and hold it at part throttle..... That being said i am not a fan of the pitts box, but i dont want to bad mouth them on a public site, its a good product just not very safe.
    asphaltcowboy1982 Thanks this.
