Permanent Sight-Glass for fuel line(s)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by VisionLogistics, Dec 3, 2012.
  1. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    I've had real problems in the past and present with air in my fuel system (ISX 475 CM870). I'm curious if anyone has installed a sight glass or comparable device on each side of the IFSM to watch for air. The shop uses a clear hose and screws it into the inlet and return ports. Would a rig like that be OK for permanent duty?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I used transparent fuel lines on intake.
    VisionLogistics Thanks this.
  4. VisionLogistics
    1,551
    978
    Dec 8, 2011
    Jellystone
    Any idea on where to look for the source of air in my return line? We're struggling to find it, and it's A LOT of air.
    Things we've checked:
    - all 4 actuators (timing and fuel)
    - Anti drain back valves
    - Bypass valve (on the back of the IFSM)
    - Injectors (it now has 6 new ones still didn't solve the problem)
    - New lift pump
    - New fuel pump
    - New fuel line on the inlet side
    No air going into the IFSM. The shop is pulling off the IFSM body today and they're going to try swapping the entire module out to see if that fixes it.
    The fuel in the return line coming off the IFSM is clean and not contaminated. If the head had a problem and was sucking air the return fuel would be contaminated with oil or coolant, yes?
    This is a real mystery.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    return stream may damage line of wrong pressure rating. It is dangerouse
  6. VisionLogistics
    1,551
    978
    Dec 8, 2011
    Jellystone
    I don't understand what you mean.
  7. VisionLogistics
    1,551
    978
    Dec 8, 2011
    Jellystone
    Oh do you mean that a clear fuel line on the return may not be the correct pressure rating and could be dangerous?
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yeah, clogged a bit may blow, especially with hot fuel
  9. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    Cat makes a sight glass that gets put in line it would work and never leak. Its made out of very thick plexie glass round pipe.
  10. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    What makes you think it is air? Sometimes the most common problems cause biggest issue. You have changed everything but return lines which if plugged can cause engine to retain air/pressure thereby causing common problem. The amount of return fuel can fill a five gallon bucket in about two or three minutes and if the return is plugged it will cause same faults.
  11. VisionLogistics
    1,551
    978
    Dec 8, 2011
    Jellystone
    I have a clear line on it and can see the air. I'm not talking an occasional bubble. I'm talking 50-75% air. Rev it up and it gets even worse, turning a semi clear stream of return fuel into nothing but foam. The shop can't figure it out, and I'm on the verge of slapping down $25k for a reman ISX from cummins just to get the truck back on the road working again. Unless they find the source of the air, I don't think it will get any better performance wise. It surges terribly, runs rough, is barely getting 5 MPG with an empty trailer (it used to get 11 MPG with my empty), knocking, no power, just totally gutless now...
    Each shop has thrown thousands of $$ worth of parts at the problem and it's still not fixed. I'm at a point where I need to cut my losses and get her back to work.
