permits question
Discussion in 'Heavy Haul Trucking Forum' started by zinita17601, Mar 4, 2014.
  1. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    im moving an oversize from brooklyn ny to virginia.got all the permits and escorts needed to make the move,when i got to the shipper i found out that the dimensions are different.the original load was supposed to be 12'wide 10'high and 40'feet long one piece but what i will be hauling is a two piecces 10'wide 15'long and 6' high each.the question is can i use the permits i got since the load is within the original dimensions or i need to get new permits.lets say i refuse to haul the load cause im gonna be sitting another two days waiting for new permits can i bill the broker for the old permits.thx
  3. passingthru69
    Use the old permits. You are not going to be over weight are you? If so you can not haul 2 pieces on the trl. and be over gross
  4. zinita17601
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    im not gonna be overweight,probably around 30,000 lbs.i just dont wanna do something i'll regret.got a $1000 ticket once in florida for having bigger dimensions but this time is the other way around.is this something you've done?thank you for the reply.i really hate the thaught of sitting two more days to get new permits.
  5. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    I think you can but not sure. It's smaller so it shouldn't be a big deal. Bigger than its an issue. I'm no expert I've only done a few od loads and permits were taken care of by others.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    As long as you don't go over the dimensions that are on your permits you are fine. I have done this many times, told the load is one size, go get it and its smaller.
    zinita17601 Thanks this.
  7. zinita17601
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    thank you guys for the help.i had a bed feeling about this load from the start,too many people involved nobody had the right answer for my questions.i went against my gut feeling,i got blinded by the money.
  8. passingthru69
    I've done it before like Oscar has stated, You are smaller not larger than the permit. You are golden so to speak. Just make sure you are not overgross. Then it will get costly..
    Fire that bad boy up and do your night move in the city...
    Good luck
  9. sky_blue
    sky_blue Light Load Member
    63
    35
    Sep 12, 2012
    Tampa, Fl
    I would reorder the ones that needed permits, at the very least reorder new york, An oversize pemit is usually pretty cheap at least compared to an overweight one, and an escort is never less than $1.30/mile. If the route for 12 wide added too many miles I would also reorder, use the first few states so you don't have to sit for those. A lot of times you can call and amend the permit too, so give that a shot
    Offender and 281ric Thank this.
  10. sky_blue
    63
    35
    Sep 12, 2012
    Tampa, Fl
    Reorder the ones that needed escorts, sorry, it was late when I wrote that
    281ric Thanks this.
  11. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    What I want to know is how the dimensions got that far off?
