I keep getting code "SAM Controller RSRVC 249s254 14" as well as "SAM SA33 SPN520403 31" on my 2010 Cascadia. I'm sure it probably something small, but I want to figure it out. Anyone know?
Pesky Freightliner code "SAM Controller RSRVC 249s254 14" What is it?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AZhomegrown, Nov 4, 2016.
SAM SA33 SPN520403 31 <--- check br25 relay circuit. its a sam cab relay.
BR25 is a bistable relay that is used for priority 1 comfort load low voltage disconnects of 12v power receptacles and reading lamps. Since it is a bistable relay it stays in it's on or off state unless triggered by the sam_cab. So it's probably staying on when it is commanded off or vise versa.
RSRVC 249s25414 <---- I think you have bad right side mirror heater
Notes: DTC for pins 575 (12Vpower receptacle4 (sleeper, cigar), BAT,X3/3), 576(12V power receptacle 5 (sleeper, cigar), BAT,X14/1), 176 (auxiliary circulation fan -sleeper,BAT,X1/13)and 553 (reading lamp (switched locally),BAT,X16/13).
Possible Causes
1. The wiring harness to the connected loads is shorted to battery
2. Bistable relay 25 is stuck
AZhomegrown Thanks this. -
