Pete 07 C-15
Discussion in 'Peterbilt Forum' started by Stormbk09, Sep 13, 2014.
  1. Stormbk09
    Stormbk09 Bobtail Member
    19
    Mar 15, 2014
    Bonner Springs, KS
    Hi drivers need some help was driving today and kept hearing whistling noises. Seemed to do it consistently when I accelerated or rapped out the rpm. Pretty quick I notice the whistling stopped and I certain I heard a Loud pop like a rush of air. I was empty and struggling get up small grades. I went and got my load and could barely move the truck up the hill. Truck is in excellent shape 846k. Please help
  3. Harley Tramp
    Harley Tramp Bobtail Member
    13
    Aug 28, 2013
    Air to air exchanger leaking or hopefully something simple like a hose busted. That causes your turbo boost not to work. Good luck
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Sounds like a blown CAC hose. You have 4 (2 on each side). The most common CAC hose to blow on those is the one right after the precooler. It is very close to the pipe that goes to the air cleaners and I've seen many rub there. If it blew because it chaffed through, adjust the pipes a bit to get at least 1/2" of clearance in there.
  5. Stormbk09
    19
    Mar 15, 2014
    Bonner Springs, KS
    Thank you. That's exactly what it was but hard to see initially as it blew around the edge of the clamp. Thanks
