pete 320 dash cluster wipering?
Discussion in 'Peterbilt Forum' started by haoleboy81, Apr 14, 2014.
  1. haoleboy81
    haoleboy81 Bobtail Member
    Honolulu, HI
    Got an 02 Pete 320 W/ a CAT C10 gauges are windshield wipering, only operable gauge is the speedo, fuses are all good, tried cluster out of another truck, same problem, any ideas would be greatly appreciated.
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    Data link problem check for loose or broken wires they will be a twisted pair also a bad ecm will do it
    haoleboy81 Thanks this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Sure sounds like a data link problem to me as well. Can you locate the ABS ECM? We had a rash of Sterlings 2002-2003's that had the clusters stop work and display "No Data" on the odometer. The problem was that the ABS ECU was faulty and killing the data link. It became pretty popular for us to unplug the ABS ECU, cycle the key and see if the dash came back on. Then we knew that the ABS was the issue.
    Worth a check. If not, then you have some wiring to trace.
    haoleboy81 and QUALITYTRUCK Thank this.
  5. haoleboy81
    Honolulu, HI
    @ jameslawton I'll check them, I have another ECM from another working truck I can try too.
    @ grapeape I'll give that abs unit a try, hopefully I won't have to chase too much wiring.
    Thanks a lot for the input guys, I'll let y'all know what I come up with.
