pete 377 cab?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by papamoonshine, Feb 17, 2016.
  1. papamoonshine
    papamoonshine Light Load Member
    103
    13
    Aug 25, 2013
    Will a 377 and 379 cab swap? Or are they not the same. Been looking at trucks and looking in to building one know where a 377 cab is but want a square hood like the 79.
  3. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    The cab themselves should interchange.
  4. catwrench55
    catwrench55 Light Load Member
    211
    88
    Jan 5, 2015
    I have a 377. Same cab, you can fit a standard 379 good but you have to have the front spring hanger-hood hinge, and move the axle forward @ 3 inches. If it's a SFA like mine.
  5. papamoonshine
    103
    13
    Aug 25, 2013
    Been looking in to buying a truck cant really find anything that I really really like was thinking about building a truck know where I could get a 377 cab with a unibilt flat top sleeper. I could pick my motor trans rearends paint it what ever I want
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    The cabs are the same, but the hoods are not interchangeable. You can not put a 379 hood on a 377 chassis without quite a bit of work. You'll need a hood, hood hinges, front spring hangers, relocate rear hangers, relocate upper shock mounts, drag link, bumper and probably some other stuff I'm forgetting. It is possible, but not worth it IMO.
    Straight Stacks Thanks this.
  7. papamoonshine
    103
    13
    Aug 25, 2013
    When I say build a truck I mean new frame rails bent with no holes I pick everything from front axle to mud flaps.. called a company on rails already.
  8. catwrench55
    211
    88
    Jan 5, 2015
    Pretty much building your own glider, quite ambitious
    papamoonshine Thanks this.
  9. Ruthless
    Ruthless Road Train Member
    8,949
    88,147
    Aug 28, 2010
    The City.
    Can it be done? Yes. If you had the time and space and tools, or you have the money.
    Do it. And put up pictures.
  10. papamoonshine
    103
    13
    Aug 25, 2013
    I'm still on the fence. When early 90's 379 with nothing special are going just under 30k and nice are in the 45 plus range I think I could build a truck cheaper... gotta talk with the guy who has the cab and sleeper
