Hope you have a lefthand drive!!!! The "C" panel is the one just left of the steering columb, usually has a pyrometer in it. Just behind it there is a master relay mounter on a horizontal aluminum deck, three leads, power, one from the ign switch, & the switched lead, have had the "wonderfully sealed Peterbilt windshields" leak water directly onto & into this relay. "Last thing" if the button won't stay in the reset position either there's a dead short or, the beaker is bad. Stil' tryn'
Pete 378 key switch problem, HELP!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jim3667, Mar 19, 2009.
Page 2 of 3
BTW!!! Congratulations on finding that breaker by the starter, that one likes to hide!!
smokinluv Thanks this. -
If the "ign" breaker is popped out, you will not have any juice # the switch. You might wind up pulling the breaker panel out to get behind it the check that breaker with your voltmeter. Could be either a dead short someplace popping it out or a bad breaker like 9axle said.
Fixed!
Thanks for your help. Turns out the circiut breaker was corroded on the back side and not making a connection. Replaced it with an inline 20 amp fuse, works great!
Thanks again! -
breakers do go bad take a test light and check both wires off the breaker if one has no power thats your problem
Just a post to anyone interested, the truck I posted originally here about is now fixed and available for purchase if anyone may be interested.
I am offering it at a sweet deal for a quick sale! -
FYI...A few specifics about it.......
1994 Pete 378 daycab
360hp? Cat with 50,000 miles on complete out of frame rebuild, performed at a Peterbilt dealership, have detailed paperwork as proof. bill was $15,000
10 speed, new clutch installed at the time of engine overhaul
new springs,shocks,tires (24.5),brakes,batteries and more...
dual stacks with Jake
wetkit
very clean 2 owner truck -
air suspension
fifth wheel has removable bar for frame or frameless trailers -
Page 2 of 3
