Pete 379 Accessory Plug fuse location.
Discussion in 'Peterbilt Forum' started by SHO-TYME, Jul 22, 2013.
  1. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    Found this today, my accessory plug went out in the upper right closet, check all the fuses at the fuse panel, all of them work. Found out there is an inline fuse near the plug, you take out the light facing back on the right hand side and you can see the plug and fuse back in there, if you can, you can reach back there with one had and get to the fuse, not sure if the outlet will pull out to make the wire drop down to replace it. I was able to reach it by hand and got it changed.
    FYI, it's also a good area to put some more insulation up in that area.
