Hello , New to the site and have some electrical questions on a 379 Pete. Have issues with the passenger headlight..on lowbeam there is no problems, but when you hit the high beams, the right side flickers on and off. Traced the problem to the 10 amp resettable circuit breaker in the fuse panel. My question is How do you remove that circuit breaker for replacement. I found if you tap the button on the breaker , it flickers the lights. Not sure if the center button removes or the whole thing. Any help would be greatly Appreciated. Thanks
