Pete 379 grounding stud???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Trcknwolf, Mar 7, 2018.
  1. Trcknwolf
    Trcknwolf Light Load Member
    57
    27
    Nov 24, 2010
    Bellevue, NE
    Maybe the dumb question of the day, but I have been told there is a grounding stud, post, whatever, that is located behind the glove box near the blower motor/box housing. I have YET to locate this. Was I given bad info, is it truck specific, no such thing exists or is it located someplace else? I am going to be doing some more rewiring (tracing & removing all remaining previous questionable & down right BAD wiring splices) which include all the chicken lights & I plan to bring all the exterior grounds inside the cab. We have already replaced the main cab wiring harness & everything under the hood has been rewired with new harnesses as well a few years back too. Just wanting a solid place to ground what I need to ground. I have multiple 370 series wiring diagrams but all are vague as to good grounding locations.
  3. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    I have never found a "grounding stud", I always use a test light to locate a good ground point and drill a hole; then I use that grounding point for any additional electrical circuitry that I add going forward.
    rabbiporkchop Thanks this.
  4. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Take out the glove box and look to the bottom right, there is an aluminum substructure and there is a heavy ground wire held in by a bolt with a star washer.
  5. Gas and diesel man
    Gas and diesel man Bobtail Member
    First question, what year of Trk? And almost all ground studs on all models are under cab drivers side bolt with 3 main grounds connected. It is right next to the cab mount vertical bolt. It the main cause of many issues. Most have broken at eyelet.
  6. Gas and diesel man
    Technically on most from that point they consider cab to be grounded. All other grounds are supplied by direct metal contact surface or components
  7. RocketScott
    RocketScott Medium Load Member
    579
    946
    Apr 10, 2013
    Kentucky
    I've got the dash apart on my '89. There are two bolts holding the aluminum cross member to the side support. One has a beefy looking ground wire #239. It looks to be 8-10 gauge.
  8. rabbiporkchop
    9,676
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    I always make my own grounding stud using one of these.
    Slowmover1 and jsnell Thank this.
  9. rabbiporkchop
    9,676
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    I forgot to show a picture of the tool I used to install the threaded inserts. You can find them on eBay and they're made in England or you can buy a Chinese made clone at Harbor Freight.
  10. RocketScott
    579
    946
    Apr 10, 2013
    Kentucky
    Riv nuts are the devil
    Nothing worse than having one spin while trying to remove a bolt, especially when you can't get to the back side.
  11. rabbiporkchop
    9,676
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    They won't spin if the hole is drilled to the proper diameter and it's a nice snug fit and it's compressed properly and you use the type with the teeth that bite into the surrounding metal like this one.
    The biggest mistake people make when installing these things is thinking they can use a standard drill bit and it stretches the hole out too big preventing it from locking in tightly when it's compressed. I always use a unibit to cut a nice clean hole in Sheet Metal.
    Maybe a little bit of Dielectric grease would be a good thing to put on the threads before putting the bolt in.
