Pete 379 No jakes/Cruse/High idle? NEED HELP PLS
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pete379yaar, Nov 14, 2023.
  1. Pete379yaar
    Pete379yaar Bobtail Member
    Alright needing some HELP!!
    The jakes/cruise/HIGH idle are not working on the truck (Pete 379). Previously the truck threw a code 241 for VSS. We switched wires from speedometer to ECM from the speed sensor and the code went away. Still no jakes or cruise.
    Replaced the speed sensor and the jakes and high idle worked for 10 mins and then stopped working again. I’m stumped on what else it can be. I’m pretty sure it’s not the clutch switch since it’s been cut and bypassed I believe. Im not sure if there is another speed sensor where the other wire can connect?
    Thanks in advance guys.
  3. Big Road Skateboard
    6,652
    37,337
    May 2, 2021
    You believe it's been bypassed? You haven't verified that?
    Oxbow Thanks this.
  4. drewfarmsllc
    drewfarmsllc Light Load Member
    83
    32
    Oct 18, 2008
    South Carolina
    Beside the accelerator pedal there are a couple of air switches screwed in an aluminum block. Can't remember exactly which one but it's bad.
