Pete 379 smoking at idle.
Discussion in 'Peterbilt Forum' started by ww04, Mar 28, 2014.
  1. ww04
    ww04 Bobtail Member
    4
    ct
    About a year ago I purchased a fixer upper 88 peterbilt ext hood 379. The truck has a 425 cat In it that smokes bad idle. New injectors were done but did not fix the problem. Any advice would be great!
  3. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    probably needs a cylinder kit, might as well do an in-frame...those ol' b model cats are pretty affordable on overhauls if you do it yourself
    Bogi Thanks this.
  4. wore out
    wore out Numbered Classic
    16,765
    205,200
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I wouldn't jump to conclusions on an inframe just yet. What color is the smoke? How does it start after sitting all night? At what rpm does the smoke clear up?
  5. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,425
    Mar 23, 2012
    Out of curiosity, what's the fuel economy like at full load with an `88, 425 Cat?
  6. spyder7723
    spyder7723 Road Train Member
    15,471
    25,077
    Mar 31, 2013
    sarasota, fl
    On my 91 379 model Pete, had 3.55 rears, 15 double over, on 24.5 tall rubber, I could get 6.5 most days just by being easy on the throttle. Would drop down to under 6 on those west coast runs. The Rockies really hurt fuel mileage.
    cabwrecker Thanks this.
  7. ww04
    ww04 Bobtail Member
    4
    ct
    Smoke clears up almost instantly when driving, but smokes at start up and idle. I was thinking it could be a leaky injector cup or injection pump issue. Wore-out, the smoke is white and the truck had a pretty big skip In the motor before the new injectors went in, the skip is gone now but still smokes on cold start.
    Thank you guys for trying to help me!
  8. ww04
    ww04 Bobtail Member
    4
    ct
    Wore-out, the truck will fire instantly right now even if she sits for a couple weeks, especially if it's plugged in with this cold New England weather. Makes me want to assume this is strictly a fuel issue and not a tired motor but I've been wrong more than once Haha
  9. wore out
    16,765
    205,200
    Jun 5, 2013
    White smoke can be coolant or fuel timing. Smell will tell the difference, we all pretty well know what coolant smells like in the exhaust. Timing will have a raw fuel smell to it. If its coolant its usually accompanied with a miss, and the list of could be's is long from cups to pitted liners. But from what you have said so far I don't think that's it. If it was a there would have been small amounts of moisture under the covers when the injectors were done. Milky looking oil and a little rust around valve springs etc. There are 2 different thickness of copper washers on the injectors, believe it or not wrong ones will alter the timing. You should have the thin one's on a 425. It could be a timing advance problem or depending on where you got the injectors, could still have one leaky nozzle. I would find a sure enuff good B model man in your area and tell him to give it a good tune up. I have to do my old rag about once a year but its worth every bit of time it takes. Not that the pump is complicated but I'm not sure of your experience level and don't want to create more trouble for you lol. I don't think its tired in the least from what you said, I'm betting on timing advance weights, or minor pump issues like contamination in the plungers causing it not to fuel correctly. Its possible it won't need anything but a good cleaning and adjustments.
    QUALITYTRUCK Thanks this.
  10. ww04
    ww04 Bobtail Member
    4
    ct
    Yes it's complete raw fuel! to the point were your eyes almost burn when standing there! Thanks so much for the advice so far I'll try and find a good mech in ct, I'll keep you posted
  11. spyder7723
    15,471
    25,077
    Mar 31, 2013
    sarasota, fl
    If I was you, I'd be very tempted to get a light load to wherever woreout is and party him to do it. He sends to know his stuff.
    wore out Thanks this.
