Pete 379 with Cat C-15 mpg?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NHL_fan, Jan 15, 2014.
  1. NHL_fan
    NHL_fan Light Load Member
    103
    34
    Jun 20, 2011
    NoVa
    Just recently purchased 379 with yellow C-15 acert 475, twin turbo, ratio 3.25 and absolutely love it... But my fuel mileage is around 4.2 - 4.8 mpg going ~70mph (1425 rpm only). I pull skateboard. My friends own Volvo's 780, one with ISX and another one with Volvo engine. So they keep telling me that they get 6.5 easily going 70 mph. Now I'm thinking if I buy ugly plastic Vulva (sorry Volvo fans) I will be able to bring a lot of extra money home. What's your drivers mpg experience with C-15 inside of brick style trucks? Can I do something to my engine? Except obvious things like replacing air filter and stuff. Does ECM tuning works and really increase mpg?
    Thanks
  3. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    910
    Mar 16, 2013
    Yes they do I drove a w900L that we took to 625 and 1850 torque and got 5.8-6.0 all day long. Pittsburgh power mufflers, twin turbo delete go to a single big turbo, Acert delete if you want to get spendy.
    NHL_fan and EverLuc Thank this.
  4. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    What tires do you have? Also are your mufflers the factory mufflers? What year is the truck and do you still have the factory fuel lines on the truck or have they been replaced?
    NHL_fan Thanks this.
  5. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    you're not going to get decent fuel milage out of an acert cat. I ran my dads acert 67 at 1425 hooked to a pot last week, over 2000 miles I averaged 3.5mpg. I get the same milage out of my E model running 80. That acert is designed to cruise at 1350 at 65 and they're know to be a fuel sucking motor. I know pulling a hopper however my dad drives that truck he can manage to get almost 6 out of it but he's also not bucking much wind dragging a hopper around. If you want to get milage out of that truck you'll need to get it breathing a lot better (get rid of them catalitc mufflers!!!!) do an ECM tune (.5mpg-1mpg) and quite possibly delete the twins and go to a single turbo. Cat's have always guzzled a little more fuel than the other motors, but those acerts are ridiculous about drinking fuel and they're gutless IMO. Our cat god is no longer giving advise on the forum. Do a search on for Mr. Haney and PM him, get his contact info and talk to him about your goals with that motor. He can tell you what to do to turn that CAT inside out.
    FYI i've talked to a couple guys that have done the single turbo conversion it turns that 475 horse kitty into a raped ape.
    TwinStickPeterbilt and NHL_fan Thank this.
  6. NHL_fan
    103
    34
    Jun 20, 2011
    NoVa
    Tires 22.5. Mufflers are stock. It's 2007. And I'm not sure about fuel lines...
  7. NHL_fan
    103
    34
    Jun 20, 2011
    NoVa
    What do u mean by saying delete Acert?
  8. TwinStickPeterbilt
    707
    910
    Mar 16, 2013
    Delete everything that makes it environment friendly. Mr.Haney would know he might suggest some other things though.
    NHL_fan and tangerineGT Thank this.
  9. wore out
    wore out Numbered Classic
    15,717
    189,934
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Tuning the Ecm will probably provide the most bang for the buck. But be sure to start out with an engine performing at its peak first. Things such as overhead set just right, absolutely no CAC leaks, Exhaust leaks etc. I have seen guys tune an engine that wasn't running at its potential level but it ran so good they couldn't really tell it had a minor issue. They say the tune helped but sound a little unhappy with it. Then the small issue is resolved and they really get a grin about the whole deal. It really amounts to how much you want to spend. Or if you can keep your foot out of it after in a case like one of ours. I have read about guys spending a bunch and gaining face changing HP but still unhappy with millage, from what I read they seemed to done every thing right. So expect better response and hope for millage. It seems every outcome is different there.
  10. mike3fan
    mike3fan Medium Load Member
    462
    514
    Jun 2, 2010
    michigan
    I had an 05 379 70" that had an accert twin turbo C15 in it, and I got 6.2mpg with it pulling a tanker. I'm thinking maybe a good tuneup is in order before a bunch of mods are done.
  11. NHL_fan
    103
    34
    Jun 20, 2011
    NoVa
    Thank you all guys for advices. As soon as I get home I'll call Antrim diesel (Greencastle PA) it's about 50 miles away from my house and see if they do ECM tuning and other things like replacing mufflers.... Anyone heard about this shop? How much is ECM tuning? 2? 3? 4 grand?
