Pete 379 with Electrical Issues
Discussion in 'Peterbilt Forum' started by truck78, Jan 18, 2014.
  1. truck78
    truck78 Bobtail Member
    5
    Jan 18, 2014
    I have 379 pete and its giving me a hard time. Electric issues, the alternator is brand new and was checked to be working but the truck still runs out of electricity every certain number of milles. Naw there is no lights on the dashboard and the dim lights switching seems to be having problems too. Its a nighmare, help!!!!!!!!!!!
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    What is the voltage at the batteries and alternator when running? What have you checked so far? Do the gauges work? What do they say (volts/amps)? Knowing the year might be helpful too.
    379exhd and KW Cajun Thank this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK.ground wire from frame to eng.an ALT.
    EverLuc Thanks this.
  5. truck78
    5
    Jan 18, 2014
    The alternator was checked and the voltage at the batteries and alternator when running is 13.5, some gauges work, some others do not, we are talking about a 2001 peterbilt 379
  6. truck78
    5
    Jan 18, 2014
    Could it be a short circuit or a bad connection on the fuse panel?
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    If the batteries have 13.5, then it's charging. What does it do when it "runs out of electricity"? Any W/S or cab leaks that may getting water on the fuse panel?
    Check voltage at fuses with circuit loaded. Turn on lights, heater motor, etc. Then check voltage at those fuses to compare to battery voltage. If you have more than few 1/10's of a volt difference, then there is a bad connection to the fuse panel.
    Check all grounds and battery connections (at the batteries and starter). I'm not sure which year they started, but on the left side above the starter, you may have a mega fuse that feeds the fuse panel. Check connections in that little box.
    Minion Man and EverLuc Thank this.
  8. truck78
    5
    Jan 18, 2014
    Thanks a lot, I'll ckeck all that!!!!!
  9. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Check voltage across all fuses and relays in fuse box--the 379 fuse panels--(down at left foot)are rather well known for water leakage over time---you may have to take entire panel out--and check behind--but you may very well find evidence of some water leakage--we have had a few nighhtmares of our own over the years---one suggestion tho--if you find it in/around ANY of the relay--dont bother to try and redo wiring to relay plug---we have found just jumping past the actual plug in--putting bare connectors on the wires and plugging relay in directly(thus bypassing plug in at panel)is easier and yields better results
    Good Luck
    Adisiwaya and EverLuc Thank this.
  10. Hurricane69
    Hurricane69 Road Train Member
    4,421
    59,740
    Sep 10, 2008
    Iowa
    Open the fuse box and turn on the dash lights. Start wiggling relays. It's a common problem with the relay spades not making good connection. If you find one making the lights flicker or go down pull it out and bend the spades out a little and put it back in.
    Rough roads in the winter can play havick on connections. Always start with the easy cheap stuff.
  11. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    If you have not found the problem it might be worth checking the low voltage disconnect it should be on left side of dash and hard to get to but you can unplug the big battery cable to it and just plug the two ends together and bypass it
