Pete 579 antenna setup
Discussion in 'CB Radio Forum' started by 6.9idi, Dec 31, 2015.
  1. 6.9idi
    6.9idi Bobtail Member
    16
    8
    Jan 20, 2013
    Higginsville, Missouri
    Alright so I Got a New Pete 579 and Its Got the cab mounted antenna brackets on it which are junk. Has anybody done their own setup like on the spot mirror like I have seen a freightliners like the bolt replacement thing. Just trying to figure sometime out to do.
  3. mike5511
    mike5511 Road Train Member
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    A picture would be helpful...........
  4. 6.9idi
    16
    8
    Jan 20, 2013
    A picture of what? the factory antenna brackets are just like 387 Petes and cascadias
  5. mike5511
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    They are not all the same.
  6. 6.9idi
    16
    8
    Jan 20, 2013
    Ok either way the factory setup is junk. So what They look like doesn't matter I wanted to know what everybody is doing for their own setups so I can get an idea on what to do
  7. mike5511
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    What they look like determines what your options are, i.e. as in what after market brackets are available. If yours is like the Cascadia, go to the link below and read, w/pics, what I did. It works as good as anything I've ever run on any truck. If that bracket won't work for your mirror, you'll need to figure out which one will. I'd start at Breedlove Mounts. I like my stuff all stainless, but aluminum will work if you clean it up once or twice a year and get rid of all the oxidation. The basics are; go with as long of an antenna as you can get by with, use good coax and check SWR before using your radio.
    https://breedlovemounts.com/Home_Page.php
    http://www.thetruckersreport.com/tr...eads/cascadia-antenna-solutions.249124/page-4
    rabbiporkchop and Ougigoug Thank this.
  8. Ougigoug
    Ougigoug Heavy Load Member
    971
    824
    Dec 4, 2012
    Planet earth
    WOW nice link have never heard of breeedlove before THX!
  9. mike5511
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    I'm not the only one that has mentioned them on here, but you are welcome.
  10. BostonTanker
    BostonTanker Road Train Member
    1,011
    680
    May 2, 2015
    Boston, MA
    I've got a 16 t680. Factory coax is junk. Got a nasty electric noise from it too. But I did get an antenna from a guy in PA. Seems to be helping. The metal antennas seem to work better if running on the factory coax. Perhaps 2 Wilson's will help? 14526035236791252103683.jpg
