Pete 587 fan not engaging...
Discussion in 'Peterbilt Forum' started by dieselwrench, Aug 27, 2013.
  1. dieselwrench
    dieselwrench Bobtail Member
    5
    Aug 27, 2013
    hey all, i'm a diesel mechanic working on a Peterbilt 587 with the Paccar engine, it came in with the fan not engaging. i've checked fuses/relays, i've tried unhooking the fan clutch actuator, nothing makes it come on. i did notice, i have power on the yellow wire, but not the brown wire. the switch is normally closed, so i'm thinking i need power on that other side to open it. is there a fuse/relay somewhere that i'm missing? i don't have a computer to hook up to it to see what the ECM is asking for, just figured i'd post here and see what y'all had to say...
    thanks a lot
    Josh
  3. Rawze
    Rawze Medium Load Member
    328
    818
    Jun 29, 2013
    inmytruck
    not sure about paccar, but most fan solenoids I have seen will turn the fan on when you 'remove' power going to them. If you unplug the solenoid, does the fan come on?
    Also some engines have a variable speed fan. There is no solenoid, but rather control wires from the ECM.
    just some thoughts on it,..Rawze
    CellNet Thanks this.
  4. dieselwrench
    5
    Aug 27, 2013
    yea, in my experience, most of them turn on when you remove power, so that's what i tried first (actually typed my steps in the wrong order above) and it didn't engage. but from what i see, the truck doesn't appear to be asking for it to come on...although i'm not sure what signal it's suppose to be sending...
  5. dieselwrench
    5
    Aug 27, 2013
    update, i found a blown fuse i overlooked prior, the fan solenoid worked for about 5-10 seconds and stopped, but the fuse wasn't blown...that would be a relay disengaging it somewhere, right? which relay would control the fan? it's not clearly marked...
  6. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    Disable the ECM & the ignition fuse and wait for 5 min to reset and plug them back in. Start the engine with the AC on & see if the fan will kick in.
    GouldExpedite and CellNet Thank this.
