Pete blower motor problems
Discussion in 'Peterbilt Forum' started by Dreamcatcher1192, Jul 22, 2013.
  1. Dreamcatcher1192
    Dreamcatcher1192 Bobtail Member
    Winchester, Ky
    I have a 2003 Pete 379 and the sleeper blower motor has quit. When I unplug motor and test wires to motor, both wires test hot with test light. Already tried new motor but, no difference. Need any help possible, please!!!!!!
  3. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    You already said it..." Both wires test hot " ...nope. One has to be ground if 2 are present. That's ur problem or did I misunderstand you?
  4. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Yup! The black should be hot the other green goes to ground (frame or battery) and white would go to ground on battery if you only have 2 wire. Green wires are usually ground to frame due to a possibilty of fire, say fuel pum.p or fuel heater etc
  5. lonncarr
    lonncarr Bobtail Member
    32
    7
    Jul 20, 2013
    Old Town, FL
    Also....Ya might wanna check your variable speed relay....that was my problem last year.
  6. Dreamcatcher1192
    Winchester, Ky
