Peterbilt 379 3406e 5ek no cruise or jakes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Thegeneral09, Jan 21, 2020.
  1. Thegeneral09
    Thegeneral09 Bobtail Member
    4
    Feb 19, 2018
    Illinois
    95 peterbilt 379 with a 5ek 3406. Have no high idle, cruise, or Jake's and according to the scanner, all switches are working, ecm shows accel mode when the high idle is held..... kinda at a loss.... pinned the wiring at the ecm and everything appears fine. Is it possible for someone to have locked cruise and Jakes out in the ecm itself?
  3. Opendeckin
    Opendeckin Medium Load Member
    454
    1,269
    May 20, 2018
    The clutch switch is almost certainly the culprit. Try pulling up on the clutch pedal while trying to set high idle.
    If not that it could be the brake switch.
    Rideandrepair and Deere hunter Thank this.
  4. Thegeneral09
    4
    Feb 19, 2018
    Illinois
    Clutch switch is good....brake switches are good... and ecm shows them working properly
    Rideandrepair Thanks this.
  5. Deere hunter
    2,117
    9,944
    Aug 5, 2017
    Shallowater Texas
    I agree , clutch switch or bad wiring harness. Common on that old of truck!
  6. Opendeckin
    454
    1,269
    May 20, 2018
    Just because the computer says so doesn't mean it's true.
  7. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    Ring since you said high idle and cruise not working as well, I don’t suspect at all any of the companants on the motor side. Engine harness does not control the cruise and high idle and Jake switch. You will want to check the truck main harness
  8. Rideandrepair
    17,356
    56,314
    Aug 8, 2015
    How do you know the clutch safety switch is good? It controls cruise/jakes switch. Did you test the switch itself? I just put the two wires together, bypassing the switch. See if cruise/Jakes work. Same with brake switch.
    Deere hunter Thanks this.
  9. Thegeneral09
    4
    Feb 19, 2018
    Illinois
    Both... and ecm reads it on/off with clutch pressed/released
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,889
    May 31, 2010
    West Harrison, In
    Have they ever worked for you?
  11. Thegeneral09
    4
    Feb 19, 2018
    Illinois
    No.... just got truck roadworthy as it was sitting... and couldn't get an answer ot of the guy I bought three truck from
