Peterbilt 379 Low Air Pressure Buzzer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chr1s427, May 12, 2012.
  1. chr1s427
    chr1s427 Bobtail Member
    18
    Feb 23, 2012
    So I was replacing the bulbs in my warning light cluster and like a dummy I left the key on while trying to put it back in place. Long story short, the low air pressure buzzer was working and when I went to put the cluster back in the dash I grounded out the buzzer and it quit working. Is there a fuse or relay for this thing somewhere? Its a 1999 379. Thanks.
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    I don't belive there is a fuse just for the buzzer you Probly burned out the circuit board pretty common on the styled dash you have while putting the dash back in with the key on ate any other things not working like earning lites and such?
  4. chr1s427
    18
    Feb 23, 2012
    Well the warning lights still work. Just no buzzer. I took it apart because the low air light wasn't working. It works now but the buzzer doesn't. Lol. Any chance to repair this thing or is it one of those goto a salvage yard and get another?
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    same thing happened to me. it was a blown fuse. don't spend what I did to find that out. check all fuses. I have a intl, so cannot help you with location of fuse, but my bet, is, it is just a fuse, not anything more.
  6. chr1s427
    18
    Feb 23, 2012
    I checked all the fuses in the left kick panel. Not sure if there are more somewhere else.
  7. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    blairandgretchen and AnneK Thank this.
  8. chr1s427
    18
    Feb 23, 2012
    Thank you very much! I will check out the schematics when I get home!
  9. chr1s427
    18
    Feb 23, 2012
    Looks like the panel itself is smoked. I can jumper power to the buzzer and it works but it doesn't work when I plug the 3 wire plug into it. Anybody got a line on some used parts? Need a warning lamp module PN 17-04120 :(
  10. Flattopper
    Flattopper Bobtail Member
    7
    Apr 28, 2012
    That happens more than you would think we A handful of them every month
