Peterbilt 379 vibrating .need help !please
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nestor, Apr 4, 2018.
  1. Nestor
    Nestor Light Load Member
    160
    23
    Oct 21, 2015
    Hoping I can get some help. I have some bad vibration going on with my dump truck tandem.
    I noticed when I’m between 30 and 50 mph it vibrates . On a scale of 1 tru 10 I would rate it at 5. It’s worst when it’s decelerating. I thought it was tranny super ten but I put it in neutral and does the same thing. I recently rebuild engine I doubt it has anything to do . I changed u joints on drive shaft the one near tranny and the next one down. My drive tires wearing out kinda weird maybe I need rotation ?
  3. Diesel Dave
    8,697
    24,798
    Jan 20, 2010
    Hesperia, Ca.
    Check the spline on the slip thru drive line. I’m referring to where the drive line meets together. Push it up and down and check for excessive play on both drive lines
    Nestor Thanks this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    With any vibration that changes on a accel or decel always check and set suspension ride height to spec. It the easiest to check and adjust first. Its also easiest to get outta wack a bit without noticing visually.
    Where is the vibration? Seat and feet?
    Nestor and ramirezbrandonc Thank this.
  5. pushbroom
    pushbroom Road Train Member
    1,779
    7,312
    Sep 1, 2012
    X2 on ride height. Solves most things. Any recent repairs to the driveline? Problem just start all of the sudden? Is it a hop, growl, shake? Pete ride height specs attached. What type of suspension do you have?
    Heavyd, SAR and Diesel Dave Thank this.
  6. Old Man
    Old Man Road Train Member
    4,597
    13,470
    Apr 3, 2009
    Oklahoma City, OK
    Carrier bearing?
    Diesel Dave Thanks this.
  7. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    If the previous solutions don't find the issue check to see if you bent the driveshaft, that's about speed range where a twisted shaft vibrates the worst.
  8. greaseburner
    greaseburner Light Load Member
    155
    45
    Check that you re-installed your driveline properly. If your u-joints are not inline, she'll vibrate .
  9. CatAddict17
    CatAddict17 Bobtail Member
    I agree with the post saying to check to make sure that your u joints are all lined up properly
  10. truck 307
    truck 307 Light Load Member
    178
    315
    Aug 11, 2014
    if you have balloon steer tires, check air psi. very common if air out 5 lbs.
    or, even as simple as mud stuck inside the wheel rim, if youve been in mudeetc (its that time of year, mud mud mud)
    Nestor Thanks this.
  11. Nestor
    160
    23
    Oct 21, 2015
    Drive line is tight
    drive line is tight
