can any one tell me fuel economy on pet 386
63" Engine Specs Cummins Engine Type ISX Horsepower 485 Transmission 13 Spd Check for Over Drive Yes Engine Brake Yes Suspension Pete Low Air Leaf Ratio 3.55 Tires 22.5 Wheels All Aluminum Wheelbase 235" Front Axle Lbs 12,000 Rear Axle Lbs 40,00
or
Cummins Engine Type ISX Horsepower 550 Transmission 13 Spd Check for Over Drive Yes Engine Brake Yes Suspension Pete Low Air Leaf Ratio 3.36 Tires 22.5LP Wheels All Aluminum Wheelbase 248" Number of Rear Axles Tandem Front Axle Lbs 12,000 Rear Axle Lbs 40,000
thanks
peterbilt 386
Discussion in 'Ask An Owner Operator' started by truckmetal13, May 4, 2009.
Cummins or Caterpillar which one is better ?
thanksLast edited: May 4, 2009
pre 07 cat
04 cats had a hard time with mileage, but there are fix's for it
as for mpg......are they used trucks?
if so the ecm will get your a close answer
if new the dealer ought to have a guesstimite for you
otherwise figure 5.5mpg......if it gets better its a bonus.....if not figure out what you can do to improve it.....hint: pay attention to your right foottruckmetal13 Thanks this. -
I don't have family and i thing to buy new truck , i hope i can earn many for truck and mortgage for my condo
