Peterbilt 387 2007 model. No brake lights.
Discussion in 'Peterbilt Forum' started by pmafia, Sep 10, 2012.
Fuse panel is behind the glove box. Open it and squeeze the sides in and let it drop down. Cleaned out of course.
Then you should see it. There is another panel outside on the firewall but I'm pretty sure the brake lights are inside.
The brake light switch you have to get your head down by the brake pedal to see it high up on the pedal arm.pmafia Thanks this. -
Thanks will look in the morning.
I have a 2009 387. Had a similar problem that ended up being the turn signal switch!
Thanks for info, at peterbilt buying switch, fuses good. Cruise does not kick off now either.
Cruise cancel and brake light switch can be two different things......At least on my 379 they are..
Thanks for replies. Put in shop cant find problem.
What was the problem, and what did they do to fix it.
yeah what did they do?
My 379 did that, it was the turn signal lever assembly.
