Peterbilt 387 Interface Module Location?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ahmadali04, May 26, 2012.
  1. ahmadali04
    ahmadali04 Bobtail Member
    28
    6
    Jan 30, 2011
    Does anyone where interface module is installed on 2007 Peterbilt 387? The interface module is what controls all of the guages like the air pressure, and air restriction guage. (I checked behind the dash panel, and behind the glove box, and could not find it.)
    I am trying to install an air weigh scale on the truck, and the truck already has a "Load Pressure Gauge" installed. I took the dash apart, but there was no air line connected behind the "Load Pressure Gauge". I called Air Weigh, and they said I need to find the interface module. (If someone has installed an air weigh on a 387, please let me know.) Thanks.
  3. Elroythekid
    Elroythekid Road Train Member
    2,611
    5,668
    Sep 9, 2010
    Halifax Nova Scotia
    The air line goes to a transducer under the cab this changes and sends it electrically to the gauge in the dash. Mine draped the bed so I ran a new hose directly from the air bag to a new analogue gauge in the dash.
  4. ahmadali04
    28
    6
    Jan 30, 2011
    Any idea where exactly under the Cab, the transducer is located. I was thinking about just extending the air line going to the transducer, and running it to inside the dash? Thanks.
  5. Elroythekid
    2,611
    5,668
    Sep 9, 2010
    Halifax Nova Scotia
    It was on the left frame rail I think but really don't remember. Easy to find the air line from the rear susp going up to it tho. I wouldn't extend the line, I started a fresh one right at the air bag and right to the back of the new gauge in the dash. It doesn't match the pete gauges but so what??? It always works.
