peterbilt 388 no quages and wont start
Discussion in 'Peterbilt Forum' started by riffd, Jun 26, 2014.
  1. riffd
    riffd Bobtail Member
    quages not operating and it will not start fuses are good and you can jump the starter and it will run but instrument cluster doesn't operate at all
    we have power to instrument cluster and ground any ideas
  3. 70s_driver
    70s_driver Medium Load Member
    611
    358
    May 4, 2014
    Theres a relay in a 379 in the panel on the left side of the steering wheel. When it went bad, my 379 would do the same thing. I wont guarantee you its in that location on yours but that could be your problem?
  4. 70s_driver
    611
    358
    May 4, 2014
    On mine, it was bolted down just inside the dash behind that dash panel.
  5. gcoffee
    gcoffee Bobtail Member
    Check the mega fuse in the battery box. The starter will still jump with that fuse out but there will not be power to the ECM.
