Peterbilt 579 floor wet in sleeper
Discussion in 'Peterbilt Forum' started by Edjahman, Nov 30, 2016.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    Hi.
    I have a 2016 579 and I noticed today that the rug in the sleeper in front of the bunk is wet. I thought it could be the refrigerator but I don't think that the refrigerator produces any water.
    So I thought maybe the rubber seal around the sleeper and I looked at that and it seems OK.
    I'm at a loss as to where it's coming from.
    Any ideas?
    It's still under warranty since it only has 80k miles on it.
    Thank you
  3. Gunner75
    Gunner75 Road Train Member
    5,701
    9,073
    Mar 17, 2014
    Jackson Center Ohio
  4. Edjahman
    648
    444
    Apr 2, 2013
  5. AbbandonZK
    AbbandonZK Light Load Member
    160
    200
    May 6, 2013
    My truck has the same problem check under the bunk. There is a hole in the floor of the sleeper or the water is getting in thru those vents on the back of the truck. I just put a spill kit under my bag of cloths. I won't be in the truck long enough for it to be a problem.
  6. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    If it a "real" fridge with a compressor and freezer it can freeze up and/or produce water. Check the drip pan and shut off the fridge for a day or so and let it fully defrost. If it's Thermoelectric then you're leaking water from somewhere else. Guessing if the bunk AC is a separate unit you could get condensation drip from the unit also.
  7. KillingTime
    KillingTime Road Train Member
    3,865
    61,880
    Mar 26, 2016
    Rockland, Maine
    I was going to ask if he suffered enuresis (sleep wizzing)... Cuts the bottle, and your consciousness right out of the equation.
  8. Dave_in_AZ
    375,212
    My '13 Cascadia leaked. But only on the instruments and electronic parts.
  9. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    There's a recall for this issue, go to a Peterbilt dealer and it'll be under warranty
  10. ExOTR
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    My 2013 Schneider Cascadia is the same, but only when turning right after a storm. I've taken to covering my radio with a towel when it starts raining :-/
  11. Belials
    Belials Light Load Member
    232
    214
    Jun 10, 2014
    Care to provide more information on this recall? I've never heard of it, and I'm looking at the list of the recalls right now and don't see it.
    Take it to a dealership then. If you have warranty, use it. I've seen too many drivers void their warranties by trying to fix stuff themselves.
